  • hugo 3 posts 23 karma points
    Aug 17, 2012 @ 20:40
    hugo
    help migrate from DNN
    hi, i have develope some vb.Net modules for DNN portals
    in a DNN module we have to have some class to access the data base
    a InfoClass, info of table fields
    ControllerClass
    DataProviderClass and a SqlDataProvider where we call the stored procedores
    i need to know the best way to do the same in Umbraco, the best way to access a table in Umbraco data base in VB.NET
    thanks
    Aug 27, 2012 @ 02:59
    hugo
    i just want to know the best practice/way to query a custom table from .Net.
    thanks
  • Richard Soeteman 4049 posts 12922 karma points MVP 2x
    Aug 27, 2012 @ 13:26
    Richard Soeteman
    If you want to support multiple databases you can use the builty-in sqlhelper. You find an example how to use this on this thread http://our.umbraco.org/forum/developers/api-questions/23592-how-to-use-SqlHelper-and-read-table-data
    But you can use any ORM (entity Framewwork, NHibernate, Ado.net) to access your data. Umbraco doesn't restrict you.
    Hope this helps you a bit,
    Richard
    Aug 27, 2012 @ 20:20
    hugo
    thanks Richard,
    for you what's the best approach to do this?
    thanks
