I want to install Embedded Content to my umbraco.
No matter I use Umb Repository or download the package and try to install as local one I get the same error:
The package contains the file UpgradeSchema.ascx, the files are just all zipped in one file so is it a problem with unzipping or with the version?
I get a similar problem when trying to install uComponents package:
I use Umbraco 4.8.1
I'll be grateful for a solution. Thank you
Just a wild guess, do you have write permissions to the /umbraco/ folder? Both of these packages place files into the /umbraco/ folder during their installation, and if they don't have permission to do so you might get the above error.
-Tom
Upload image
Problem installing a package
The file '/umbraco/EmbeddedContent/UpgradeSchema.ascx' does not exist.
The file '/umbraco/plugins/uComponents/uComponentsInstaller.ascx' does not exist.
I use Umbraco 4.8.1
-Tom
