Hi all,
I use XSLT in my app, it works fine. Today I have a small issue as bellow:
1. The app have three page with 3 template: master, submaster1 (inside the master), submaster2 (inside the master).
2. the code below is in the header of master template:
[CODE]
<form method="get" action="/search.aspx?"> <input type="text" id="txtTopSearch" name="search"/> <input type="submit" value=""> </form>
[/CODE]
3. I have some other buttons in the submaster1 template.
4. The issue occurs when I click on search button, it always redirect to the current page instead of search.aspx.
Please help me solve it.
Thanks!
Change the Form Method from get to post instead this should redirect you to the your search.aspx page
I solved this issue, It works fine now with two <form> tags.
1. <form method="get" action="/search.aspx?"> after the body tag
2. <form> .... search textbox </form>
Upload image
XSLTSearch help me, please?
Hi all,
[CODE]
</form>
[/CODE]
Thanks!
Thanks!
