I'm using SqlHelper in my Umbraco Base methods to query this custom table I added to my database for custom information. This is my code :
var sqlHelper = umbraco.BusinessLogic.Application.SqlHelper;
var reader = sqlHelper.ExecuteReader(
"SELECT * " +
"FROM myCustomTable " +
"WHERE SomeId = @SomeId",
sqlHelper.CreateParameter("@SomeId", someIdFromMyCode)
if (reader.Read())
var someOtherId = reader.GetInt("SomeOtherId");
if (someOtherId > 0) {
// Do stuff
Ok so this works very well, my question is that I'm wondering how SqlHelper will manage DBConnection and ressources and when will it free up the memory and etc. I don't want this to be too heavy for my server, should I wrap this in a using or something else?
Since this is in base, this is called by Ajax-jquery so it can get it "often". What are the best practices around this SqlHelper. I tried looking in umbraco source but it's quite deep in there through factory patterns and stuff that I don't really want to read through.
Here is the answer. Umbraco's SqlHelper uses Microsoft.ApplicationBlocks.Data.SqlHelper which handles connection and ressouce management. So no need to worry about this. Found this in umbraco.datalayer/SqlHelpers/SqlServer/SqlServerHelper.cs:
using SH = Microsoft.ApplicationBlocks.Data.SqlHelper;
Using SqlHelper, freeing up ressources after use.
var sqlHelper = umbraco.BusinessLogic.Application.SqlHelper; var reader = sqlHelper.ExecuteReader( "SELECT * " + "FROM myCustomTable " + "WHERE SomeId = @SomeId", sqlHelper.CreateParameter("@SomeId", someIdFromMyCode) ); if (reader.Read()) { var someOtherId = reader.GetInt("SomeOtherId"); if (someOtherId > 0){ // Do stuff } }
Maybe someone here knows about this?
Thank you!
Sébastien
Cheers!
Seb
