  • Sébastien Richer 194 posts 430 karma points
    Jan 07, 2013 @ 20:23
    Sébastien Richer
    Uninstalling my package, problem removing hierarchised document types
    I have these hierarchised document typesthat I install in my package, but when I try to uninstall, I get an error message: "Can't delete a Document Type used as a Master Content Type. Please remove all references first!"
    How can I tell my package to uninstall the document types in the "child first" order? Or maybe there is another way to go about this.
    Thanks!
    Seb
    Jan 07, 2013 @ 20:29
    Dirk De Grave
    unfortunately, you can't tell your package to uninstall in a specified order i'm afraid. Only thing you could do is create your own "uninstall" task to run on uninstall of the package. But honestly, sounds more as a core code issue which you should log here. Provide as much info as possible
    /Dirk
    Sébastien Richer
    In my package, I see this line and if I simply "reverse" it, my package uninstalls correctly :
    <documenttypes>1076,1077,1078,1079,1080,1081,1082,1083</documenttypes>
    Which make sense...
    Jan 07, 2013 @ 20:31
    Sébastien Richer
    Hi Dirk,
    This feels weird though, basically means that all the packages available either don'T use hierarchised document types or manage it manually. I guess I can delete the document types by code, I have code already running on uninstall, but it does seem odd...
    Thanks!
    Jan 07, 2013 @ 20:47
    Sébastien Richer
    Hi again Dirk,
    I found this issue : http://issues.umbraco.org/issue/U4-1351 Upvoted and commented hehe :D
