Looking for help designing a user control for umbraco
Greetings,
I am new to the Umbraco system and was hoping to recieve some advice regarding a user control I plan on building.
Basically I have an external database with more than 50 tables, I want to allow users to import data into these tables (one at a time) with a csv file, VisualFoxPro, or an excel document.
I plan on using the ADO.NET framework and DataTables in my user control (c#)
Besides registering my .NET user control in the umbraco system, and setting up my Connection Strings
what are some other considerations I need to be wary of and would adding something like this be practical or do-able?
Greetings,
-John
It should be no problem. (From a Umbraco standpoint, i.e. assuming you're able to make the user control itself)
Just create the user control and add it to the dashboard.config (and add the connection string to web.config).
thanks!
