  • Torleif 11 posts 68 karma points
    Apr 16, 2013 @ 19:47
    Torleif
    Using OAuth Providers with MVC 4 in Umbraco 6+
    Does anyone have experience on how to approach this ?
    I want to use this tutorial:
    http://www.asp.net/mvc/overview/getting-started/using-oauth-providers-with-mvc
    and use Umbraco Membership to save members.
    I know this may be a complex question, but any help is appreciated.
  • Simon steed 378 posts 700 karma points
    Aug 06, 2014 @ 01:01
    Simon steed
    How did you get on? I'm part way through an implementation based upon the oauth examples
  • Governor Technology 146 posts 551 karma points
    Nov 21, 2014 @ 17:11
    Governor Technology
    Hi Simon
    Not sure if this would help, but uShare makes use of OAuth to authorise Umbraco to do some simple sharing on your behalf from the backoffice. It might provide some further useful examples. You can find the source on CodePlex.
    Rigardt
    Dec 01, 2014 @ 14:48
    Simon steed
    Thanks Richard - will check it out
