  • Adriano Fabri 469 posts 1633 karma points
    Apr 24, 2013 @ 16:40
    Adriano Fabri
    Problems when create custom tree node
    I have a problem when I try to add a custom tree node in developer section.
    I'm using umbraco v4.11.06 and I created a custom project to add a custom tree in developer section.
    When I refresh the page, I don't see my custom tree.
    In trees.config this is the line for my Custom Tree Node (It seems OK):
    <!-- Custom -->
    <add silent="false" initialize="true" sortOrder="7" alias="myAlias" application="developer" title="My Custom Tree" iconClosed=".sprTreeFolder" iconOpen=".sprTreeFolder_o" assembly="myCustomTree" type="loadMyCustomTree" action="" />
    What's wrong? Any idea? Thank you in advance.
    This is my class code.
    using System.Text;
    using umbraco.businesslogic;
    using umbraco.cms.presentation.Trees;
    namespace MyAliasAppTree
        [Tree("developer""myAlias""My Custom Tree"".sprTreeFolder"".sprTreeFolder_o"""falsetrue, 7)]
        public class loadMyAlias : BaseTree
            public loadClientTools(string application) : base(application)
            protected override void CreateRootNode(ref XmlTreeNode rootNode)
                rootNode.Icon = FolderIcon;
                rootNode.OpenIcon = FolderIconOpen;
                rootNode.NodeType = "init" + TreeAlias;
                rootNode.NodeID = "init";
            public override void Render(ref XmlTree tree)
                var mct = XmlTreeNode.Create(this);
                mct.Text = "My Custom Tree";
                mct.Icon = "images/myCustomTree.gif";
                mct.Action = "javascript:openMyCustomTree()";
                // Add the node to the tree
                tree.Add(mct);
            public override void RenderJS(ref StringBuilder Javascript)
                Javascript.Append(@"
                   function openMyCustomTree()
                       parent.right.document.location.href = 'plugins/MyCustomProject/myPage.aspx';
    Apr 25, 2013 @ 09:48
    Dave Woestenborghs
    In your config file the type doesn't match the type in the code example.
    Type should be "MyAliasAppTree.loadMyAlias"
    Dave
