Hi, can anybody help me? I'm usually develop website using PHP. And I'm really new to this ASP.NET. I have no knowledge about ASP. And I have ASP project which I develop using umbraco CMS. Can anyone guide me how to using ajax here?
Before now, I only doing umbraco with its document type and XSLT. but at this point I need to use ajax here. In PHP I just need to make a PHP file and call it with ajax. I already googled up, and many people say about /base. I really dont understand about this base. But what I get is, I need to make .aspx file and call it with jquery ajax (remind me if I'm wrong), adn thas /base is the simple .aspx file.
I read the example and get the code bellow. But again, I'm really noob in this ASP. I open up VS 2010, and I choose MVC c# project (is that correct)? and Then I see my project tree on my right hand panel. But I dont know where should I paste the code.
Can anyone guide me how to develop aspx file? and I also read after compiling the file I need to copy the dll file. I'm very gratefull if you explain this step also.
Using Ajax in Umbraco for Noob Dev
Thank you very much
Maybe a late reply but here it goes anyways
For creating base extensions you only need a dll so a Class Library project should do it.
Next step is to make a class that has the appropriate attributes like you implemented
You then build your solution and put the dll into your umbraco bin folder
No need to do anything else but call the url.
To call a method from base it goes like this
For the method Hello it looks like this:
Note: the alias & method are case sensitive
Which will return xml:
If you don't want xml set the parameter 'returnXml' to false
Which then will return:
You can also pass parameters to a method:
The url looks then like this: http://domain/base/myAlias/Hello/paulus/ which gives:
To use this with $.ajax you just set the url parameter to the url above
Thats the basics to use base
Hope this helps :)
