  • k 256 posts 654 karma points
    May 08, 2013 @ 07:48
    k
    Activating comment section for blog
    HI,
    I have deactivated the comment section in the blog and I am unable to reactivate it again. Can someone please help on how to activate the comment again.
    kusum
    May 08, 2013 @ 21:40
    Hi Kusum and welcome to our :)
    Could you ellaborate a bit more about what version of Umbraco you're using and do you have any idea about what blog-package is being used? This way it will be a bit easier to help you out.
    May 09, 2013 @ 08:19
    k
    Hi jan,
    Version of Umbraco : umbraco v 4.7.2
    Package version  :  2.1.1.1
    Thanks for helping :)
    kusum
    May 09, 2013 @ 09:06
    Hi Kusum
    That's what we're here for :)
    I suppose you have installed "blog4umbraco" or is it uBlogsy? If it's blog for Umbraco I'm not sure it's 100% compatibale with 4.7.2 at all and hence will act weird.
    If it's uBlogsy then we can probably figure it out since it should be compatible with 4.7.2 if I remember correctly (Have not been using it that much).
    May 09, 2013 @ 09:17
    k
    I am using uBlogsy
