  • Sangeeta 20 posts 80 karma points
    Jun 04, 2013 @ 11:34
    Sangeeta
    Best Blogging system for Umbraco CMS
    I want to integrate blogs to my existing Umbraco CMS site. After few Rnd i found few opions but couldnt figure out which one will be best for my requirement. Here is the list:
    1) Blog 4 Umbraco
    2) uBlogsy
    3) uNews
    4) ChokaBlog
    5) Smart Blog
    I want a blogging system which is SEO Friendly, Umbraco 6 compatible easy interface and easy to use.
    i wish others can share their experience of using any of above blog systems.
  • Alex Skrypnyk 6083 posts 23481 karma points MVP 6x admin c-trib
    Jun 04, 2013 @ 11:57
    Alex Skrypnyk
    Hello Sanqeeta ))
    I think uBlogsy is the best )
    Alex
    Jun 04, 2013 @ 13:40
    Sangeeta
    Alex. Thanks for your answer, but can you please brief me the reason why you think uBlogsy as best blog. I can see Blog4Umbraco has been downloaded more than uBlogsy and also there are many people using blog4Umbraco.
    If you have some strong reason behind using uBlogsy then please share.
    If anyone can answer:  I can also see, uBlogsy is far compatible with Umbraco 6. Is that not case with blog4Umbraco.
  • Richard Soeteman 4014 posts 12698 karma points MVP
    Jun 04, 2013 @ 16:40
    Richard Soeteman
    +1 for uBlogsy all the other systems are not actively developed. uBlogsy works with the latest versions of Umbraco and works with MVC
    Richard
    Jun 04, 2013 @ 16:46
    Alex Skrypnyk
    We implemented blog with uBlogsy several times, and each time it was successful )
    Alex
  • Mark Slade 46 posts 97 karma points
    Oct 27, 2013 @ 13:44
  • Sarthak 5 posts 54 karma points
    Jul 21, 2014 @ 12:39
    Sarthak
    i am using umbraco v 4.11.6 (Assembly version: 1.0.4834.19775) the issue is when ever the server shutdown or restarted.Everytime i need to republish the pages which are not loaded. So please let me know the route cause for this issue if anyone knows or any other stuffs that can be done to over come from this
    Thanks in Advance
