  • kim Thomsen 59 posts 277 karma points
    Oct 25, 2013 @ 16:13
    kim Thomsen
    IE 11 login problems
    Hi Umbraco people,
    I have just upgraded to windows 8.1 and got the new IE browser.
    And for some wired reson this has stoped working:
     FormsAuthentication.SetAuthCookie(m.LoginName, true);
    I have also tryed
     Member.AddMemberToCache(m, true, new TimeSpan(10, 0, 0, 0));
    With no result
    Best regards Kimtho
  • Jamie 35 posts 87 karma points
    Nov 15, 2013 @ 03:36
    Jamie
    Hi Kimtho,
    If you are using Window Server 2008 or later, need to install .NET Framework 4.5 to work.
    If you are using older version - go to this site http://stackoverflow.com/a/19855256/1297563
    Source from this site - http://www.hanselman.com/blog/IE10AndIE11AndWindows81AndDoPostBack.aspx
  • naphong 1 post 71 karma points
    Jun 10, 2016 @ 05:56
    naphong
    Hi all,
    I got this problem also,Can't login membership.
    About Chrome & FireFox can login but IE can't login always null.
    I have tested using two following method but both not work.
    Test 1# use UmbracoForm
    enter code here
    @using (Html.BeginUmbracoForm
       @Html.TextBoxFor(m => loginModel.Username, new { @id = "Name", @class = "form-control", @name = "username" })
       @Html.PasswordFor(m => loginModel.Password, new { @id = "password", @class = "form-control", @name = "password", @type = "password", required = true })
       <input type="submit" value="Enter" class="btn btn-primary" />
    loginStatusModel.IsLoggedIn =true
    Chrome and firefox is true but IE11 is false.
    IE11# @loginStatusModel.Username is null
    Test 2# use Normal Form,Create new controller for post membership
            @Html.TextBox("username");
            @Html.Password("Password");
             <input type="submit" />
    Controller:
    [HttpPost] [ActionName("MemberUmbLogin")]
    public ActionResult MemberUmbLoginPost(MemberUmbLoginModel model)
            string returnUrl = GetValidReturnUrl(Request.UrlReferrer);
            if (Membership.ValidateUser(model.Username, model.Password))
                FormsAuthentication.SetAuthCookie(model.Username, model.RememberMe);
                Response.Cookies.Add(new HttpCookie("Username", model.Username));
                Response.Cookies["UserName"].Expires = DateTime.Now.AddYears(30);
                return Redirect("/login3");
    Same result in Test 1#
    IE11# @loginStatusModel.Username is null.
    I don't know how to fix this.
    Thanks for helps.
    Naphong saebae.
