  • Tom Maton 387 posts 660 karma points
    Nov 04, 2013 @ 10:50
    Tom Maton
    Creating multi-level custom tree in 6.1.6 with mixture of own data and umbraco nodes
    Hi All,
    I've not used Umbraco in a while (shamefully) and now trying to move my custom section and tree from 4.8 to the latest 6.1.6 but it no longer seems to be rendering the tree its just displaying the spinning image.
    One of the things I've noticed is that Document is now deprecated I've looked at the ContentService (which I believe its bee replaced with) but I dont seem to be retrieving any content using this. If anyone has any examples or blog posts they could point my in the correct direction that would be great.
    Thanks in advance.
    Tom
  • Garðar Þorsteinsson 119 posts 566 karma points
    Nov 04, 2013 @ 12:58
    Garðar Þorsteinsson
    Hi Tom, I just had to find a way to create custom section in Umbraco 6.1.6 and boy that took some reading, the documentation is scaddered all over the place.
    I'm going to write a blog post about all the steps for creating the custom application but this should help you until I get to it.
    If anyone can better my code then that would be appreciated.
    You dont need to include anything into the tree config file, it wil be added there automaticly.
    [Tree("Application", "Application", "Application")]
        public class populateTree : BaseTree
            public populateTree(string application)
                : base(application)
            protected override void CreateRootNode(ref XmlTreeNode rootNode)
                rootNode.Icon = FolderIcon;
                rootNode.OpenIcon = FolderIconOpen;
                rootNode.NodeType = "init" + TreeAlias;
                rootNode.NodeID = "init";
                rootNode.Action = "javascript:openCategory(-1);";
            public override void Render(ref XmlTree tree)
                // Get the current database object
                var db = ApplicationContext.Current.DatabaseContext.Database;
                // Fetch a collection from the db.
                List<Category> listOfCategories = null;
                int key = -1;
                if (!string.IsNullOrEmpty(this.NodeKey))
                    key = Convert.ToInt32(this.NodeKey);
                listOfCategories = db.Fetch<Category>("SELECT * FROM Categories WHERE deleted=@0 ORDER BY name", false);
                if (listOfCategories != null)
                    foreach (Category category in listOfCategories.Where(x => x.parentId == key))
                        string id = category.treeId.ToString();
                        // Create tree node
                        var node = XmlTreeNode.Create(this);
                        node.NodeID = id;
                        node.Text = category.name;
                        node.Icon = "folder_o.gif";
                        node.Action = "javascript:openCategory(" + node.NodeID + ");";
                        // Add child nodes
                        bool hasChildren = listOfCategories.Where(x => x.parentId == category.treeId).Any();
                        node.Source = hasChildren ? this.GetTreeServiceUrl(node.NodeID) : "";
                        // Add the node to the tree
                        tree.Add(node);
            public override void RenderJS(ref StringBuilder Javascript)
                Javascript.Append(@"
                function openCategory(id) {
                    document.getElementById('right').scrolling = 'auto';
                    UmbClientMgr.contentFrame('../App_Plugins/PluginName/Category/List?id=' + id);
    Nov 04, 2013 @ 15:35
    Tom Maton
    Cheers mate,
    I'll take a look tonight and let you know how I get on.
    Thanks, Tom
