I am trying to create a surface controller using this video but for some reason it won't handle my posts. this is my controller code:
public class ContactFormController : SurfaceController { // // GET: /ContactForm/
public ActionResult Index() { return PartialView("ContactForm", new ContactFormViewModel()); } [HttpPost] public ActionResult FormSubmit(ContactFormViewModel model) { return RedirectToCurrentUmbracoPage(); } }
this is my cshtml code:
@using (Html.BeginUmbracoForm<SurfaceControllersSample.Controllers.ContactFormController>("FormSubmit")) { <div> @Html.TextBoxFor(m => m.Name, new { placeholder = "Name" }) </div> <div> @Html.TextBoxFor(m => m.Email, new { placeholder = "Email" }) </div> <div> @Html.TextAreaFor(m => m.Message, new { placeholder = "Message" }) </div> <div> <button id="submit">Send</button> </div> }
it will go to the "Index" method but not the "FormSumbit" Method. Any ideas?
Hi Moran,
I believe you should change your class name from ContactFormController to ContactFormSurfaceController and also in your cshtml file
@using (Html.BeginUmbracoForm<SurfaceControllersSample.Controllers.ContactFormSurfaceController>("FormSubmit"))
hope that helps.
Cheers
Ali
Hi Thanks, I named it something else and forgot to attach the code for the most important thing, my controller :) here it is:
public class ContactFormController : SurfaceController { // // GET: /ContactForm/ public ActionResult Index() { return PartialView("ContactForm", new ContactFormViewModel()); } [HttpPost] public ActionResult FormSubmit(ContactFormViewModel model) { return RedirectToCurrentUmbracoPage(); } }
Even if I tried to insert a breaking point in the FormSubmit, But it won't get there.
Any thoughts?
Comment author was deleted
Seems good :) but make sure you are running in MVC mode and the template you are outputting the form on is a razor view and not a .net masterpage
And make sure you don't have nested forms...
The controller's name must be suffixed with the term 'SurfaceController' based on this page:
@Ali Don't think that's mandatory...
Ok So I just need to rename my 'ContactFormController' to 'ContactFormSurfaceController'? I did that and updated my code accordingly but still no post :( this is my code in the master page maybe I need to call the FormSumbit method also
@inherits Umbraco.Web.Mvc.UmbracoTemplatePage @{ Layout = "Master.cshtml"; } <h1>@CurrentPage.Name</h1> @Html.Action("Index", "ContactFormSurface")
Thanks Tim My bad I had a form tag in the master page, old habits die hard :) Thanks everyone :)
P.S Great work with the videos Tim :)
@Moran thanks :) and glad I could help
handle post in surface controller
Hi Moran,
ContactFormControllertoContactFormSurfaceControllerand also in your cshtml filehope that helps.
Cheers
Ali
Any thoughts?
Hi Moran,
