  • badigard 7 posts 38 karma points
    Apr 24, 2014 @ 09:43
    badigard
    Right way to create a validation class
    Hi all,
    Need you help in creating a custom validation class for Umbraco properties.
    The class will get a Node ID, check if it's valid and return a string to the image.
    Something like:
            public static string GetImageLink (int link) {
                if (link != null && link > 0 )           {
                   var imageLink = umbraco.Media(link).umbracoFile; }
    Questions:
    1. Where should this class be created? it's a MVC project
    2. What libraries should I add (and how) so commands like umbraco.Media / uQuery.GetNode / Node.GetProperty will work?
    Thanks.
