I am trying to install the Moxiemanager plugin in TinyMCE in Umbraco 6.1.6, TinyMCE3, but I can not get it to show up in the richtext editor.
Does anyone know if Moxiemanager is compatible with TinyMCE3? It does say it only works with .NET 4.5 so I upgraded the Umbraco-project to .NET 4.5.
I basically followed the recipe for TinyMCE here: http://www.moxiemanager.com/documentation/index.php/Installation_net.
I am assuming Step 5 has to be done for Umbraco at:/Config/TinyMceConfig.config something like below. I stole the image-icon here as I was unsure where to locate moxiemanager's.
<command> <umbracoAlias>moxiemanager</umbracoAlias> <icon>images/editor/image.gif</icon> <tinyMceCommand value="" userInterface="true" frontendCommand="moxiemanager">moxiemanager</tinyMceCommand> <priority>80</priority> </command>
<plugin loadOnFrontend="false">moxiemanager</plugin>
It does show up in the richtext editor datatype and I can enable it, but it does not show up when editing properties under Content.
Hi Rune
Have you tried recycling the app pool to see if it has an effect?
Hi Jan,
Yes, I tried touching the web.config and recycling manually as well. I also sent this to Moxiemanager - let's hope they have an answer.
Umbraco 6.1.6 + Moxiemanager-plugin for TinyMCE3 - does that work?
<command> <umbracoAlias>moxiemanager</umbracoAlias> <icon>images/editor/image.gif</icon> <tinyMceCommand value="" userInterface="true" frontendCommand="moxiemanager">moxiemanager</tinyMceCommand> <priority>80</priority> </command>It does show up in the richtext editor datatype and I can enable it, but it does not show up when editing properties under Content.
Hi Rune
Hi Jan,
