  • RoelAlblas 50 posts 61 karma points
    Nov 01, 2009 @ 18:44
    RoelAlblas
    problem with create a new node
    I get the following error when I create a new node in self configured tree
    Input string was not in a correct format.
    I just don't see what I'm doing wrong here. This is my code in the save event of a class inherited with ITaskReturnUrl
    public
    bool Save()
    int idReturned =
    Application.SqlHelper.ExecuteScalar<int>
    "INSERT INTO ketelstoringen_sup_supplier(sup_name) VALUES(@sup_name), SELECT @@Identity",
    Application.SqlHelper.CreateParameter("@sup_name", Alias)
    _returnUrl =
    string.Format("plugins/loadSupplier.aspx?id={0}", idReturned);
    return true;
    sup_name is varchar field of 254 and the identity is there a sup_id that is incremental and a primary key. I didn't figure out where Alias comes from but it should be the textfield. Its configured in the class like this:
    public string Alias
    get
    return _alias;
    set
    _alias =
    value;
     The UI.xml is created like this:
    nodeType alias="supplier">
    header>Supplier</header>
    usercontrol>/create/simple.ascx</usercontrol>
    tasks>
    create assembly="Ketelstoringen" type="ketelstoringenSupplierTasks" />
    delete assembly="Ketelstoringen" type="ketelstoringenSupplierTasks" />
    tasks>
    nodeType>
     The delete function is working so I don't think there is a problem in ui.xml
    Everything looks fine to me but there is some hick up. Can anyone solve my blindness ...?
    Thanks!
    Roel
    Nov 04, 2009 @ 20:47
    RoelAlblas
    Anyone having a suggestion? I just don't get it to work.
    Thanks!
    Roel
    Nov 08, 2009 @ 18:50
    RoelAlblas
    Solved!!
    NodeId was a string instead of an integer.
  • Max 144 posts 166 karma points
    May 30, 2012 @ 10:54
    Max
    how did you solve it please suggest  thank you
    here is my code
     public class LoadIssueTree: BaseTree
            public LoadIssueTree(string application) : base(application) { }
            protected BaseTree _baseTree;
            protected override void CreateRootNode(ref XmlTreeNode rootNode)
                rootNode.Icon = FolderIcon;
                rootNode.OpenIcon = FolderIconOpen;
                rootNode.NodeType = TreeAlias;
                rootNode.NodeID = "init";
            protected override void CreateRootNodeActions(ref List<IAction> actions)
                actions.Clear();
                actions.Add(ContextMenuSeperator.Instance);
                actions.Add(ActionRefresh.Instance);
     public override void Render(ref XmlTree tree)
                   if (string.IsNullOrEmpty(this.NodeKey)) {
                    //Add the first level
                    XmlTreeNode xNodeProfileKeywords = XmlTreeNode.Create(this);
                    xNodeProfileKeywords.NodeID = "manageIssues";
                    xNodeProfileKeywords.NodeType = "manageIssues";
                    xNodeProfileKeywords.Text = "IssuesMain";
                    xNodeProfileKeywords.Icon = "folder.gif";
                    xNodeProfileKeywords.HasChildren = true;
                    xNodeProfileKeywords.Source = this.GetTreeServiceUrl(xNodeProfileKeywords.NodeID);
                    xNodeProfileKeywords.Menu.Clear();
                    xNodeProfileKeywords.Menu.AddRange(new List<IAction>() { ActionNew.Instance });
                   // xNodeProfileKeywords.Menu.AddRange(new List<IAction>() { ActionDelete.Instance });
                    xNodeProfileKeywords.Menu.AddRange(new List<IAction>() { ActionRefresh.Instance });
                    tree.Add(xNodeProfileKeywords);
                    XmlTreeNode xNodeCompanies = XmlTreeNode.Create(this);
                    xNodeCompanies.NodeID = "manageIssueStatus";
                    xNodeCompanies.NodeType = "manageIssueStatus";
                    xNodeCompanies.Text = "IssuesStatus";
                    xNodeCompanies.Icon = "folder.gif";
                    xNodeCompanies.HasChildren = true;
                    xNodeCompanies.Source = this.GetTreeServiceUrl(xNodeCompanies.NodeID);
                    xNodeCompanies.Menu.Clear();
                    xNodeCompanies.Menu.AddRange(new List<IAction>() { ActionNew.Instance });
                   //xNodeCompanies.Menu.AddRange(new List<IAction>() { ActionDelete.Instance });
                   xNodeCompanies.Menu.AddRange(new List<IAction>() { ActionRefresh.Instance });
                    tree.Add(xNodeCompanies);
                    XmlTreeNode xNodepriority = XmlTreeNode.Create(this);
                    xNodepriority.NodeID = "manageIssuesPriority";
                    xNodepriority.NodeType = "manageIssuesPriority";
                    xNodepriority.Text = "IssuesPriority";
                    xNodepriority.Icon = "folder.gif";
                    xNodepriority.HasChildren = true;
                    xNodepriority.Source = this.GetTreeServiceUrl(xNodepriority.NodeID);
                    xNodepriority.Menu.Clear();
                    xNodepriority.Menu.AddRange(new List<IAction>() { ActionNew.Instance });
                   // xNodepriority.Menu.AddRange(new List<IAction>() { ActionDelete.Instance });
                    xNodepriority.Menu.AddRange(new List<IAction>() { ActionRefresh.Instance });
                    tree.Add(xNodepriority);
                    XmlTreeNode xNodecat = XmlTreeNode.Create(this);
                    xNodecat.NodeID = "manageIssuesCategory";
                    xNodecat.NodeType = "manageIssuesCategory";
                    xNodecat.Text = "IssuesCategory";
                    xNodecat.Icon = "folder.gif";
                    xNodecat.HasChildren = true;
                    xNodecat.Source = this.GetTreeServiceUrl(xNodecat.NodeID);
                    xNodecat.Menu.Clear();
                    xNodecat.Menu.AddRange(new List<IAction>() { ActionNew.Instance });
                   // xNodecat.Menu.AddRange(new List<IAction>() { ActionDelete.Instance });
                    xNodecat.Menu.AddRange(new List<IAction>() { ActionRefresh.Instance });
                    tree.Add(xNodecat);
                   else if (this.NodeKey == "manageIssues")
                       IRecordsReader reader = Application.SqlHelper.ExecuteReader("select * from IssuesTable");
                       while (reader.Read())
                           XmlTreeNode xNode = XmlTreeNode.Create(this);
                           xNode.NodeID = reader.GetInt("ID").ToString();
                           xNode.NodeType = "issues";
                           xNode.Text = reader.GetString("IssueName");
                           xNode.Icon = "docPic.gif";
                           xNode.Action = "javascript:openIssueTree(" + reader.GetInt("id").ToString() + ")";
                           tree.Add(xNode);
                   else if (this.NodeKey == "manageIssueStatus")
                       IRecordsReader reader = Application.SqlHelper.ExecuteReader("select * from IssueStatus");
                           xNode.NodeID = reader.GetInt("StatusID").ToString();
                           xNode.Text = reader.GetString("IssueStatus");
                           xNode.Icon = "wall-brick.png";
                           xNode.Action = "javascript:openIssueStatus(" + reader.GetInt("StatusID").ToString() + ")";
                           xNode.Menu.Clear();
                          // xNode.Menu.AddRange(new List<IAction>() { ActionNew.Instance });
                           xNode.Menu.Add(ActionDelete.Instance);
                           tree.Add(xNode);
                   else if (this.NodeKey == "manageIssuesPriority")
                       IRecordsReader reader = Application.SqlHelper.ExecuteReader("select * from IssuesPriority");
                           xNode.NodeID = reader.GetInt("PriorityID").ToString();
                           xNode.Text = reader.GetString("Priority");
                           xNode.Icon = "wand.png";
                           xNode.Action = "javascript:openIssuePriority(" + reader.GetInt("PriorityID").ToString() + ")";
                           xNode.Menu.Clear();
                           //xNode.Menu.AddRange(new List<IAction>() { ActionNew.Instance });
                           tree.Add(xNode);
                   else if (this.NodeKey == "manageIssuesCategory")
                       IRecordsReader reader = Application.SqlHelper.ExecuteReader("select * from IssuesCategory");
                           xNode.NodeID = reader.GetInt("CategoryID").ToString();
                           xNode.Text = reader.GetString("IssuesCategory");
                           xNode.Icon = "zone.png";
                           xNode.Action = "javascript:openIssuesCategory(" + reader.GetInt("CategoryID").ToString() + ")";
                           xNode.Menu.Clear();
                           tree.Add(xNode);
            public TreeService GetTreeService(int keyId, string nodeKey)
                return new TreeService(keyId, _baseTree.TreeAlias, _baseTree.ShowContextMenu, _baseTree.IsDialog, _baseTree.DialogMode, _baseTree.app, nodeKey);
            public override void RenderJS(ref StringBuilder Javascript)
                Javascript.Append(
                        function openIssueTree(id) {
                            parent.right.document.location.href = 'plugins/editIssues.aspx?id=' + id;
                        function openIssueStatus(id) {
                            parent.right.document.location.href = 'plugins/editIssueStatus.aspx?id=' + id;
                     function openIssuePriority(id) {
                            parent.right.document.location.href = 'plugins/editIssuePriority.aspx?id=' + id;
                   function openIssuesCategory(id) {
                            parent.right.document.location.href = 'plugins/editIssuesCategory.aspx?id=' + id;
    mu Ui  file
    <nodeType alias="manageIssues">
            <header>IssuesMain</header>
             <usercontrol>/create/simple.ascx</usercontrol>
            <tasks>
           <create assembly="IssuesUmbracoSection" type="Tasks.IssueTask" />
          <delete assembly="IssuesUmbracoSection" type="Tasks.IssueTask" />
            </tasks>
        </nodeType>
        <nodeType alias="manageIssueStatus">
            <header>IssueStatus</header>
            <tasks>
           <create assembly="IssuesUmbracoSection" type="Tasks.IssueStatusTasks" />
          <delete assembly="IssuesUmbracoSection" type="Tasks.IssueStatusTasks" />
            </tasks>
        </nodeType>
        <nodeType alias="manageIssuesPriority">
            <header>IssuesPriority</header>
            <tasks>
           <create assembly="IssuesUmbracoSection" type="Tasks.IssuePriorityTask" />
          <delete assembly="IssuesUmbracoSection" type="Tasks.IssuePriorityTask" />
            </tasks>
        </nodeType>
        <nodeType alias="manageIssuesCategory">
            <header>IssuesCategory</header>
            <tasks>
           <create assembly="IssuesUmbracoSection" type="Tasks.IssuesCategoryTask" />
          <delete assembly="IssuesUmbracoSection" type="Tasks.IssuesCategoryTask" />
            </tasks>
        </nodeType>
    anu idea wny ItaskReturnUrl  create and delete nto working giving me string format errrors
