  • Nikolas van Etten 202 posts 162 karma points
    Nov 06, 2009 @ 13:16
    Nikolas van Etten
    Problem with sessions (Object reference not set to an instance of an object.) on root node
    I've added a usercontrol to the master template which displays information based on a session.
    When trying to access the root node of my site I get a "Object reference not set to an instance of an object." error. This only occurs when accessing www.mysite.com and not when accessing www.mysite.com/home.aspx which are both the same page.
    Just to make sure the problem is related to the session I have only included the following line in the Page_Load of my usercontrol.
    Response.Write(HttpContext.Current.Session.Count.ToString());
    And it results in the "Object reference..." error. Anyone have a clue why this happens? What's different from loading mysite.com and mysite.com/home.aspx when they both should return the same node?
  • Christian W. Larsen 27 posts 49 karma points
    Nov 06, 2009 @ 17:09
    Christian W. Larsen
    Have you added runAllManagedModulesForAllRequests="True" to the system.webServer/modules section in web.config?
    <modules runAllManagedModulesForAllRequests="True">
    Best
    Christian
    Nov 06, 2009 @ 19:46
    Nikolas van Etten
    Seems to do the trick! Thanks very much... ;)
  • Petr Snobelt 923 posts 1535 karma points
    Nov 06, 2009 @ 23:12
    Petr Snobelt
    @ChrisW: Can you explain this behavior?
  • Amir Khan 1289 posts 2746 karma points
    Apr 20, 2010 @ 00:23
    Amir Khan
    I second the request for an explaination of this behavior. It solved some major woes I was having with membership and member login issues!
  • Michael Latouche 504 posts 819 karma points MVP 4x c-trib
    Apr 23, 2010 @ 00:59
    Michael Latouche
    Same for me! So, what's the trick ;-)?
    Jun 24, 2010 @ 16:42
  • Jan Fosgerau 65 posts 89 karma points
    Jun 28, 2010 @ 10:47
    Jan Fosgerau
    When i did this it completely bugged out my umbraco ?
    unable to save - said duplicate template.
    and i decided to restart umbraco - unable to start it.
    i removed the
    and it worked again - of course i still have the error with object reference.
