Trying to write a 404 handler, following this guide and this thread, but it is not working correctly. I am not sure I am registering the event correctly?
then in the handler (code below) contentRequest.Is404 ALWAYS = false, even though the pages don't exist. When I try searching for example asdf.aspx, the contentRequest uri will show only /asdf (not the .aspx part). I end up seeing the default 404 page (set in umbracoSettings.config)
The handler gets fired, contentRequest.Is404 returns true, but I end up with the ugly 404. I would like it to fall through and return the default 404 page (since the handler isn't doing anything yet)
There is not much code in the handler yet, I am just trying to get it to fire and work correctly
using Umbraco.Core;
using Umbraco.Core.Services;
using Umbraco.Web;
using Umbraco.Web.Routing;
using umbraco;
using System.Linq;
namespace WHRX.Helpers {
public class NotFoundContentFinder : IContentFinder {
public bool TryFindContent(PublishedContentRequest contentRequest) {
if (contentRequest.Is404) {
var rootNode = uQuery.GetRootNode();
if (rootNode != null) {
// do something
return contentRequest.PublishedContent != null;
ok this is what I ended up doing that seems to work (adds 404 handler, defaults to default 404 page in config file if no other solution found). I added code to look up and display the default 404 page.
Umbraco.Core.Models.IPublishedContent foundContent = null;
// add special code here to look up how to handle the 404
// if nothing found, try to find default error page
if (foundContent == null) {
// attempt to get default Error page
var defaultErrorPageList = umbraco.UmbracoSettings._umbracoSettings.SelectNodes("/settings/content/errors/error404");
if (defaultErrorPageList.Count > 0) {
int i404PageId = 0;
int.TryParse(defaultErrorPageList.Item(0).InnerText, out i404PageId);
foundContent = contentRequest.RoutingContext.UmbracoContext.ContentCache.GetById(i404PageId);
// if you want, fall back to a hard coded number
foundContent = contentRequest.RoutingContext.UmbracoContext.ContentCache.GetById(1062);
if (foundContent != null) contentRequest.PublishedContent = foundContent;
return contentRequest.PublishedContent != foundContent;
What I've done is i searched for the level 1 tree node, then search for the 2nd level tree where the document type is equal to "Templateerrorpage". In this scenario, every website must have 404 page in level 2.
//Check request is a 404
//Get the home node
var home = contentRequest.RoutingContext.UmbracoContext.ContentCache.GetByRoute("/");
//Get the 404 node
var notFoundNode = home.Children.Single(x => x.DocumentTypeAlias == "Template_error_page");
//Set Response Status to be HTTP 404
contentRequest.SetResponseStatus(404, "404 Page Not Found");
//Set the node to be the not found node
contentRequest.PublishedContent = notFoundNode;
I had a similar issue on Umbraco 7.5.4. The problem in my case was that I didn't have a template set for the 404 page, so even though it was found, it could not be rendered.
404 handler using IContentFinder not working ?
Using Umbraco v6.2.1
When I have the following:
When I change it to:
protected override void ApplicationStarting(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext) { ContentLastChanceFinderResolver.Current.SetFinder(new NotFoundContentFinder()); base.ApplicationStarting(umbracoApplication, applicationContext); }then the handler never gets fired at all. You see the default 404 page (from umbracoSettings.config)
And finally, when I have this:
protected override void ApplicationStarting(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext) { ContentFinderResolver.Current.RemoveType<ContentFinderByNotFoundHandlers>(); ContentLastChanceFinderResolver.Current.SetFinder(new NotFoundContentFinder()); base.ApplicationStarting(umbracoApplication, applicationContext); }The handler gets fired, contentRequest.Is404 returns true, but I end up with the ugly 404. I would like it to fall through and return the default 404 page (since the handler isn't doing anything yet)
using Umbraco.Core; using Umbraco.Core.Services; using Umbraco.Web; using Umbraco.Web.Routing; using umbraco; using System.Linq; namespace WHRX.Helpers { public class NotFoundContentFinder : IContentFinder { public bool TryFindContent(PublishedContentRequest contentRequest) { if (contentRequest.Is404) { var rootNode = uQuery.GetRootNode(); if (rootNode != null) { // do something } } return contentRequest.PublishedContent != null; } } }ok this is what I ended up doing that seems to work (adds 404 handler, defaults to default 404 page in config file if no other solution found). I added code to look up and display the default 404 page.
add the event handler (3rd version from above)
and the handler:
public bool TryFindContent(PublishedContentRequest contentRequest) { Umbraco.Core.Models.IPublishedContent foundContent = null; if (contentRequest.Is404) { // add special code here to look up how to handle the 404 // if nothing found, try to find default error page if (foundContent == null) { // attempt to get default Error page var defaultErrorPageList = umbraco.UmbracoSettings._umbracoSettings.SelectNodes("/settings/content/errors/error404"); if (defaultErrorPageList.Count > 0) { int i404PageId = 0; int.TryParse(defaultErrorPageList.Item(0).InnerText, out i404PageId); foundContent = contentRequest.RoutingContext.UmbracoContext.ContentCache.GetById(i404PageId); } // if you want, fall back to a hard coded number foundContent = contentRequest.RoutingContext.UmbracoContext.ContentCache.GetById(1062); } } if (foundContent != null) contentRequest.PublishedContent = foundContent; return contentRequest.PublishedContent != foundContent; }Hi Karen,
Thank you for your post, this helped me alot in Umbraco 7.1.9
I thought I'll share what i did as well. My code is based on your code above and the link you've given above
http://creativewebspecialist.co.uk/2013/08/07/the-new-way-to-do-a-404-umbraco-handler/
Cheers
Shinsuke
Hi Shinsuke,
Perhaps you will also find this information useful http://24days.in/umbraco/2014/urlprovider-and-contentfinder/. It´s a blogpst written by Jeroen Breuer from the last year Umbraco advent calendar.
Hope this helps,
/Dennis
For anybody else that comes across this...
Anyone had any issues with url that comes with special characters like
/fr-ca/à-propos-de/fdsafdsf
The Custome 404 Handler is not picking up with special characters in the url. Any idea?
The normal IIS error, i found out why.
within the HttpError tag in web.config, i need the existingResponse="PassThrough"
