Help With Strongly Typed Views for Randomised Output
Hi there
Firstly, I am a NOOB to MVC using Umbraco.
I have been tasked with outputting all nodes of a certain type in a random order, but for that random order to remain consistent for a 24 hour period. To date I have not found an Out-of-the-box way to achieve this with partial views. Does anyone know if this is possible?
A solution I currently have in my head is :
create a model which only contains the properties I need for my page output, and add a property for a random number
within the custom controller create list of my custom model including the "randomisation" logic
within the view output the list created by
So I have scoured Google for some help and did find some resources but have been unable to get anything working as yet.
My model is as follows: ----------------------------------- using System; using System.Collections.Generic; using System.Linq; using System.Web;
namespace umb724.Models { public class PersonModel { public int ID { get; set; } public string FirstName { get; set; } public string Surname { get; set; } public string URL { get; set; } } }
My controller is as follows (pseudo entries purely in an attempt to wire up the MVC functionlity (random functionality will be included later): -----------------------------------
using System.Collections.Generic; using System.Linq; using System.Web; using System.Web.Mvc; using umb724.Models; using Umbraco.Web.Mvc;
namespace umb724.Controllers { public class PersonController : SurfaceController { public ActionResult Person() { List personModel = new List();
Thanks for your great suggestion re caching - I had been wondering about this aspect so very timely.
The randomisation aspect I haven't worked out yet but have some ideas in my head - my initial pain point is in getting the MVC part to work but you my have solved that in your code too.
I will have a play with your suggestion and see how I get on.
Again, thanks for the feedback - truly appreciated.
Hi there
using System;
using System.Linq;
using System.Web;
using System.Linq;
using System.Web;
PersonModel pm = new PersonModel();
pm.FirstName = "Joe";
pm.Surname = "Bloggs";
pm.ID = 1234;
personModel.Add(pm);
PersonModel pm2 = new PersonModel();
pm.FirstName = "John";
pm.Surname = "Doe";
pm.ID = 4321;
personModel.Add(pm2);
return View(personModel);
My View is as follows:
@model umb724.Models.PersonModel
Layout = "~/Views/Master.cshtml";
@foreach (var item in Model.PersonListing)
@item.FirstName
Is anyone able to please assist and get me on track with respect to this ?
Alternatively, can anyone sugest a simpler way to generate a random output that changes based on the day.
Thanks, Nigel
I think your idea is there but you don't have a way of making it ocnsistant for 24 hours?
How About using the built in umbraco ApplicationCache to cache for 24 hours?
Entirely untested but something like.....
Hi Carl
Regards
Nigel
