  • OddConcept 2 posts 22 karma points
    Jun 29, 2015 @ 21:08
    OddConcept
    Surface Controller With Grid
    I am new to MVC and this is my first attempt at creating a SurfaceController. It is a basic form with 2 dropdowns. Origin Port and Destination port. When the user selects an origin port then there is an ajax call that gets available destination ports.... All this is working until here.
    When I submit the form I need to go to the Database and get all Records with the Origin Port and Destination Port that were selected. When I get to the HttpPost call "RateRequest" how do I send the values back to the cshtml page. The "GetAllFreightRates" call has records but the WebGrid does not bind with the new values.
    I would greatly appreciate a kick in the right direction...
    This is my surface Controller:
    public class RateRequestSurfaceController: SurfaceController
            [HttpPost]
            public ActionResult RateRequest(RateRequestModel model)
               ////***** At this point only model.OiginPort and model.DestinationPorts have value.
                if (ModelState.IsValid)
                    model.FreightRates = FreightRateServices.GetAllFreightRates();
                return CurrentUmbracoPage();
            [HttpPost]
            public ActionResult BindDischargePorts(string originPortId)
                try
                    var data = PortServices.GetAvailableDischargePorts(string.IsNullOrEmpty(originPortId) ? (int?)null : Convert.ToInt32(originPortId)).ToList();
                    data.Insert(0, new PortModel() { Name = "-- All --", Id = 0 });
                    return Json(new { ok = true, data, message = string.Empty });
                catch (Exception ex)
                    return Json(new { ok = false, message = ex.Message });
            [ChildActionOnly]
            public ActionResult RenderActionResult()
                var rateRequestmodel = new RateRequestModel
                    OriginPorts = PortServices.GetAvailableLoadingPorts().AsEnumerable().Select(x => new SelectListItem
                            Text = x.Name,
                            Value = x.Id.ToString()
                        }).ToList(),
                    DestinationPorts = PortServices.GetAvailableDischargePorts().AsEnumerable().Select(x => new SelectListItem
                            Text = x.Name,
                        }).ToList(),
                    FreightRates = Enumerable.Empty<FreightRateModel>()
                return PartialView("RateRequest", rateRequestmodel);
    My Model:
    public class RateRequestModel {
    [DisplayName("Origin Port")]
    public IEnumerable<SelectListItem> OriginPorts { get; set; }
    public int OriginPortId { get; set; }
    [DisplayName("Destination Port")]
    public IEnumerable<SelectListItem> DestinationPorts { get; set; }
    public int DestinationPortId { get; set; }
    public IEnumerable<FreightRateModel> FreightRates { get; set; }
    cshtml:
    @using (Html.BeginUmbracoForm("RateRequest", "RateRequestSurface", Model, new { @class = "rateRequestForm" }))
        @Html.ValidationSummary(true)
        <div>
            @Html.ValidationSummary()
        <div>
            @Html.LabelFor(x=> x.OriginPorts):
            @Html.DropDownListFor(x => x.OriginPortId, Model.OriginPorts, "-- All --")
        <div>
            @Html.LabelFor(x => x.DestinationPorts):
            @Html.DropDownListFor(x => x.DestinationPortId, Model.DestinationPorts, "-- All --")
        <input type="submit" value="Search Rate Request" class="jbutton" />
        <div id="divFreightRates" class="innerContentContainer ui-helper-padding">
            <div class="row-fluid">
                    //var grid = new WebGrid(FreightRateServices.GetAllFreightRates());
                    var grid = new WebGrid(Model.FreightRates, rowsPerPage: 25, ajaxUpdateContainerId: "divFreightRates", defaultSort: "OriginPort");
                    //grid.Bind(Model.FreightRates, rowCount: Model.FreightRates.Count(), autoSortAndPage: false);
                    grid.Pager(WebGridPagerModes.All);
                <div>
                    @grid.GetHtml(
                        tableStyle: "gvThemeBlue gvResults"
            $(function () {
                var gvResults = $('.gvResults');
                if (gvResults != null && gvResults.children('thead').length > 0) {
                    //var hCol1 = gvResults.find('tr th').filter(function () { return $(this).text() === "Id"; }).index();
                    gvResults.dataTable({
                        "bJQueryUI": true,
                        "bPaginate": true,
                        "iDisplayLength": 50,
                        "sPaginationType": "full_numbers",
                        "bLengthChange": false,
                        "bInfo": false,
                        "bFilter": true,
                        "bAutoWidth": false,
                        "sDom": '<"H"Tfr>t<"F"ip>',
                        "aaSorting": [],
                        //"aoColumnDefs": [{ "bVisible": false, "aTargets": [hCol1] }, { 'bSortable': false, 'aTargets': [0] }],
                        "fnRowCallback": function (nRow) {
                            return nRow;
            $('#OriginPortId').on('change', function () {
                var selectedValue = $("#OriginPortId option:selected").val();
                var destinationPortDropdown = $("#DestinationPortId");
                $.post('@Url.Action("BindDischargePorts", "RateRequestSurface")', { originPortId: selectedValue }, function (data) {
                    if (data.ok) {
                        destinationPortDropdown.empty();
                        $.each(data.data, function (index, itemData) {
                            destinationPortDropdown.append($('<option></option>').val(itemData.Id).html(itemData.Name));
                    } else {
                        alert('Error Loading Data.');
        </script>
    Jun 30, 2015 @ 20:26
    OddConcept
    I ended up passing the data in the ViewData, because I could not figure out how to pass the data back using the Model.
    [HttpPost]
            BindDropDowns();
            ViewData["FreightRates"] = TestClass.GetInfo(model.OriginPortId, model.DestinationPortId);
