I'm just extending the excellent Open ID package for umbraco and I need
to add some configuration capabilities to it. What is the appropriate
location in which to store the config? The Web.config? A file in the
umbraco/config directory?
I would prefer 2. or 3. but it depends on the security settings you need. Read/write access or so. If you could create a folder for the package you can propably be sure that you can write also a file to the folder. Also think about the users: if the user has to edit the file the user has to find it in an easy way => option 2.
Appropriate place for package config info
I'm just extending the excellent Open ID package for umbraco and I need to add some configuration capabilities to it. What is the appropriate location in which to store the config? The Web.config? A file in the umbraco/config directory?
In my opinion there are three options:
hth, Thomas
