  • KHALL 5 posts 75 karma points
    Sep 16, 2015 @ 15:28
    KHALL
    E-commerce solution for existing site
    I have inherited a B2B Umbraco website which is set up to sell products - except there is currently no online payment system.
    This is because there is a very complex pricing structure which needs some manual input into.
    So a customer chooses a product, selects the options, essentially adds products to a basket, and then the request is submitted to a member of staff, who manually calculates and provides a quote.
    We are trying to implement an automated process which allows for the calculation of product costs, plus a payment gateway.
    We need therefore: - a way to create a complex cost calculator based on the options for different products and product uses - a solution for taking online payments
    Being new to Umbraco, I wondered if there were any suggestions?
  • Jason Prothero 422 posts 1243 karma points MVP 2x c-trib
    Sep 16, 2015 @ 16:31
    Jason Prothero
    Is the current e-commerce solution built using a package such as uCommerce, TeaCommerce, etc? Or is it a custom build?
    Sep 22, 2015 @ 09:17
    KHALL
    Not sure, I will find out - thanks for the reply.
    Sep 23, 2015 @ 07:56
    KHALL
    It's a custom build using Umbraco v6.Hope that helps!
    Sep 23, 2015 @ 16:50
    Jason Prothero
    Given there is a customer calculation involved in the process, my guess is that making a custom checkout process may be the best way forward. My guess is forcing the custom calculations into a "shopping cart / ecommerce" package may be about the same amount of work. However, you could ping then and see if they have any advice (Merchello, uCommerce, Tea Commerce, etc).
    As long as you are familiar with ASP.NET MVC and payment gateways, it shouldn't be too bad. If you don't have any experience with Umbraco, I would recommend buying a month of Umbraco.tv and review that to get a good intro to how things work. Taking a training wouldn't be a bad idea either.
    Other than that if you can get your questions here to something a little more focused and less specific, there are some really smart and friendly people who will help.
    Good luck!
    Sep 30, 2015 @ 09:21
    KHALL
    Thanks so much Jason, that's a good place to start.
