I think I have a logic issue with my Angular that I need some help on.
We have a service that connects to a DB that gets saved values so our Angular form can get the values and use them. That is all set up.
My issue is, in our form we have 1 radio button list using an ng-repeat to generate the list and 3 dropdown lists. Our dropdown lists are triggering and update function to update the values of themselves. We are showing and hiding the dropdown menus based on the radio button lists selection (I will post the code). This should be noted we are using Umbraco CMS that this control is being used for, but this is not the actual issue.
The issue is, we console our response the value of the radio button list outputs fine to the selection we chose, BUT when I select one of the dropdown list items, the value of the dropdown list returns to the previously selected value. Any help figuring this out would be greatly appreciated.
Code is below:
my.controller.js
angular.module("umbraco")
.controller("Our.GalaxyEventSelectorController", function ($scope, $routeParams, notificationsService, GalaxyEventSelectorResource) {
$scope.emptyList = [{}];
$scope.ETypeRadio = { 0: "NA", 1: "RepeatingTimedEvent", 2: "RepeatSingleDayEvent", 3: "SingleTimedEvent" };
GalaxyEventSelectorResource.getEventById($routeParams.id, $scope.model.alias).then(function (response) {
// console.log("REsponse: " + response);
console.log("intial load on DOM load")
var resp = (response.data.indexOf("{") > -1 ? angular.fromJson(JSON.parse(response.data)) : "");
$scope.previousSelectedTypeOfEvent = (resp == "" ? "" : resp.TypeOfEvent);
$scope.previousSelectedEventTypeId = (resp == "" ? 0 : resp.EventTypeId);
$scope.previousSelectedEventName = (resp == "" ? "" : resp.EventName);
$scope.previousSelectedEventId = (resp == "" ? 0 : resp.EventId);
$scope.previousSelectedEventDate = (resp == "" ? "" : resp.EventDate);
//This loads the selection the initial time.
$scope.selectedTypeOfEvent = $scope.previousSelectedTypeOfEvent; //THIS Gets the previous radio button selection
//init EventTypeId dropdown
var initIdx = 0;
$scope.getEventTypeIds(true, initIdx);
}).then(function() {
//init Name dropdown
var initIdx = -1;
$scope.getEventNames(true, initIdx, $scope.previousSelectedEventTypeId);
}).then(function () {
//init EventIds and Dates dropdowns
var initIdx = -1;
$scope.getEventIdsAndDates(true, initIdx, $scope.previousSelectedEventName);
$scope.getEventDatesOnly(true, initIdx, $scope.previousSelectedEventName);
// init model values
$scope.typeOfEventRadioSelected($scope.previousSelectedTypeOfEvent);
$scope.updateModelValue(
$scope.previousSelectedTypeOfEvent,
$scope.previousSelectedEventTypeId,
$scope.previousSelectedEventName,
$scope.previousSelectedEventId,
$scope.previousSelectedEventDate);
$scope.updateModelValue = function (typeOfEvent, eventTypeId, eventName, eventId, eventDate) {
$scope.model.value = {
TypeOfEvent: typeOfEvent,
EventTypeId: eventTypeId,
EventName: eventName,
EventId: eventId,
EventDate: eventDate
console.log("Scope load and scope change");
console.log($scope.model.value);
//not used...attempting to make the visual nice onscreen but causes unpredictable loss of data. could be useful
$scope.addSpacesToCamelCase = function(txt) {
return txt.replace(/([a-z])([A-Z])/g, "$1 $2");
$scope.typeOfEventRadioSelected = function(selectedTypeOfEvent) {
//triggered when radio button selected.
var typeOfEvent = selectedTypeOfEvent;
var eventTypeId = $scope.selectedGalaxyEventTypeId != null
? $scope.selectedGalaxyEventTypeId.EventTypeId
var eventName = "";
var eventId = "";
var eventDate = "";
var initIdx = -1;
$("#GalaxyEventNameDdl").show();
$("#GalaxyEventIdDdl").show();
$("#GalaxyEventDatesDdl").show();
switch (selectedTypeOfEvent) {
case "NA":
$scope.getEventNames(false, initIdx, eventTypeId);
$scope.GalaxyEventIdsAndDates = $scope.initial;
$scope.GalaxyEventDates = $scope.initial;
$("#GalaxyEventNameDdl").hide();
$("#GalaxyEventIdDdl").hide();
$("#GalaxyEventDatesDdl").hide();
break;
case "RepeatingTimedEvent":
//$scope.getEventNames(false, initIdx, eventTypeId);
eventName = $scope.selectedGalaxyEventName != null
? $scope.selectedGalaxyEventName.EventName
break;
case "RepeatSingleDayEvent":
$scope.getEventDatesOnly(false, initIdx, eventName);
eventDate = $scope.selectedGalaxyEventDates != null
? $scope.selectedGalaxyEventDates.EventDate
break;
case "SingleTimedEvent":
$scope.getEventIdsAndDates(false, initIdx, eventName);
eventId = $scope.selectedGalaxyEventId != null
? $scope.selectedGalaxyEventId.EventId
break;
typeOfEvent,
eventTypeId,
eventName,
eventId,
eventDate
$scope.eventTypeIDSelected = function (selectedEventTypeId) {
console.log("Event Type ID selected");
//triggered when EventTypeId dropdown is changed. update the datatype value & provide names in name dropdown
var initIdx = -1;
$scope.getEventNames(false, initIdx, selectedEventTypeId.EventTypeId);
$scope.GalaxyEventIdsAndDates = $scope.initial;// NOT WORKING TO WIPE THE LIST...WHY?
$scope.GalaxyEventDates = $scope.initial; // NOT WORKING TO WIPE THE LIST...WHY?
$scope.selectedTypeOfEvent,
selectedEventTypeId.EventTypeId,
$scope.eventNameSelected = function (selectedName) {
//triggered when eventName dropdown is changed. update the datatype value & provide dates and ids in dropdowns
var initIdx = -1;
$scope.getEventIdsAndDates(false, initIdx, selectedName.EventName);
$scope.getEventDatesOnly(false, initIdx, selectedName.EventName);
$scope.selectedGalaxyEventTypeId.EventTypeId,
selectedName.EventName,
$scope.eventIdSelected = function (selectedEventId) {
//triggered when eventId dropdown is changed. update the datatype value & init date dropdown
var initIdx = -1;
$scope.getEventDatesOnly(false, initIdx, $scope.selectedGalaxyEventName.EventName);
$scope.selectedGalaxyEventName.EventName,
selectedEventId.EventId,
selectedEventId.EventDate);
$scope.eventDatesSelected = function (selectedEventDate) {
//triggered when eventDate dropdown is changed. update the datatype value & init Id dropdown
var initIdx = -1;
$scope.getEventIdsAndDates(false, initIdx, $scope.selectedGalaxyEventName.EventName);
selectedEventDate.EventDate);
$scope.getEventTypeIds = function (initVal, idx) {
GalaxyEventSelectorResource.getEventIds().then(function (eventTypeIds) {
$scope.GalaxyEventTypes = eventTypeIds.data;
console.log("successfully retrieved galaxyeventids");
//console.log("Event Type IDs:", eventTypeIds.data[0]);
if (initVal) {
$scope.GalaxyEventTypes.some(function (x, i) {
if (x.EventTypeId == $scope.previousSelectedEventTypeId) {
idx = i;
return true;
$scope.selectedGalaxyEventTypeId = $scope.GalaxyEventTypes[idx];
function (data) {
console.log("failed to retrieve galaxyeventids");
$scope.getEventNames = function (initVal, idx, eventTypeId) {
GalaxyEventSelectorResource.getEventNamesByEventId(eventTypeId).then(function (eventNames) {
$scope.GalaxyEventNames = eventNames.data;
console.log("successfully retrieved galaxyeventnames");
if (initVal) {
$scope.GalaxyEventNames.some(function (x, i) {
if (x.EventName == $scope.previousSelectedEventName) {
idx = i;
return true;
$scope.selectedGalaxyEventName = $scope.GalaxyEventNames[idx];
function (data) {
console.log("failed to retrieve galaxyeventnames");
$scope.getEventIdsAndDates = function(initVal, idx, eventName) {
GalaxyEventSelectorResource.getEventIdsAndDatesByEventName(eventName).then(function (eventIds) {
$scope.GalaxyEventIdsAndDates = eventIds.data;
console.log("successfully retrieved galaxyIdsanddates");
if (initVal) {
$scope.GalaxyEventIdsAndDates.some(function(x, i) {
if (x.EventId == $scope.previousSelectedEventId) {
idx = i;
return true;
$scope.selectedGalaxyEventId = $scope.GalaxyEventIdsAndDates[idx];
function(data) {
console.log("failed to retrieve galaxyIdsanddates");
$scope.getEventDatesOnly = function (initVal, idx, eventName) {
GalaxyEventSelectorResource.getEventDatesByEventName(eventName).then(function (eventDates) {
$scope.GalaxyEventDates = eventDates.data;
console.log("successfully retrieved galaxydates");
if (initVal) {
$scope.GalaxyEventDates.some(function (x, i) {
if (x.EventDate == $scope.previousSelectedEventDate) {
idx = i;
return true;
$scope.selectedGalaxyEventDates = $scope.GalaxyEventDates[idx];
function (data) {
console.log("failed to retrieve galaxydates");
EventSelector.html
<div ng-controller="Our.GalaxyEventSelectorController">
<h5>Select Type of Event</h5>
<!--<div>-->
<div ng-repeat="n in ETypeRadio">
<!-- need to use ng-click as an ng-change on an ng-repeat element does not work -->
<!-- <input type="radio" ng-model="selectedTypeOfEvent" name="tOfE" ng-click="typeOfEventRadioSelected(selectedTypeOfEvent)" ng-value="{{n}}" value="{{n}}" />{{n}}-->
<!--</div>-->
<h5>Galaxy Event Type</h5>
<select ng-model="selectedGalaxyEventTypeId" ng-change="eventTypeIDSelected(selectedGalaxyEventTypeId)" ng-options="eventType.EventTypeId + ' - ' + eventType.EventTypeIdDescription for eventType in GalaxyEventTypes track by eventType.EventTypeId"></select>
<br/>
<div id="GalaxyEventNameDdl">
<h5>Galaxy Event Name</h5>
<select ng-model="selectedGalaxyEventName" ng-change="eventNameSelected(selectedGalaxyEventName)" ng-options="name.EventName for name in GalaxyEventNames">
<option value=""> --- Select Event Name ---</option>
</select>
<br />
<div id="GalaxyEventIdDdl">
<h5>Galaxy Event Id</h5>
<select data-ng-model="selectedGalaxyEventId" ng-change="eventIdSelected(selectedGalaxyEventId)" ng-options="id.EventId + ' - ' + id.EventDate for id in GalaxyEventIdsAndDates track by id.EventId">
<option value=""></option>
</select>
<br />
<div id="GalaxyEventDatesDdl">
<h5>Galaxy Event Date</h5>
<select data-ng-model="selectedGalaxyEventDates" ng-change="eventDatesSelected(selectedGalaxyEventDates)" ng-options="date.EventDate for date in GalaxyEventDates">
</select>
We have a .resource.js but this is just performing gets to load our original data from our service.
Angular JS radio lists and dropdowns. Issue with dropdowns changing value of radio list value when triggered
I think I have a logic issue with my Angular that I need some help on. We have a service that connects to a DB that gets saved values so our Angular form can get the values and use them. That is all set up.
Code is below:
my.controller.js
EventSelector.html
