Hi i m able to create packagesuccessfully.But when i m trying to install it is giving error below
The connection was resetThe connection to the server was reset while the page was loading. * The site could be temporarily unavailable or too busy. Try again in a few moments. * If you are unable to load any pages, check your computer's network connection. * If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
any one please guide me to solve this error
---vijay
I have the same problem trying to install the MultipleFileUploadPackage.
I am having the same problem.
Packages are created successfully but when I test an installation on a clean install I get this message.
The strange thing is earlier versions of the package work?
Anyone any ideas?
Thanks,Barneyps - I'm using umb 4.5.1 on localhost
Ok the error seems to be because the package file size is now something like 25Mb!
The packages that previously installed successfully were about 3.5Mb.
So I unzipped the new package (which doesn't work) and found three or four previous versions of the package within the actual archive.
I deleted these and then re-zipped up the folder (thus re-creating the package archive file).
And then the package installs correctly.
Hope that helps someone else...
Barney
Package installation problem(The connection was reset)
moments.
connection.
---vijay
Anyone any ideas?
Barney
Barney
