  • Christoffer Andersen 23 posts 53 karma points
    Feb 18, 2010 @ 12:39
    session problem in static base class
    Greetings
    I have made use of the /base methods in umbraco and got it all working. However if I want to make use of a Session element where I have refered to HttpContext.Current.Session["MyRequestedSession"], whenever I try to read a value it crashes. I have offcourse tested if there are any info in the session, which there however I suspect that the error lies in /base being url accessed and it therefor might not know anything about sessions.
    So my question is simply put if anyone got a session element to work in there /base in a static content, and if they could then post an example of how it works.
    With kind regards
    Christoffer
    Feb 18, 2010 @ 12:46
    Oh yeah forgot basic info.
    Using umbraco 4.0.3
    IIS 7
    and the error I was presented with upon trying to access my session is foloowing:
    <error>
    MESSAGE:
    Exception has been thrown by the target of an invocation.
    STACKTRACE:
       at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
       at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
       at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
       at umbraco.presentation.umbracobase.requestModule.invokeMethod(restExtension myExtension, Object[] paras)
    INNEREXCEPTION:
       at Designit.Umb.Newsletter.Custom.EmbedNewsletter.Embstep4(String templateAlias) in C:\Projects\Designit.Umb.Newsletter\Designit.Umb.Newsletter.Custom\EmbedNewsletter.cs:line 108
    </error>
  • Ron Brouwer 273 posts 768 karma points
    Feb 18, 2010 @ 14:32
    Ron Brouwer
    Hi Christoffer,
    Have you tried adding the following to your web.config?
    <modules runAllManagedModulesForAllRequests="true">
    Ron
    Feb 18, 2010 @ 14:55
    That approach might work, however I don't have access to the web.config file, but atm I have solved it temporarely with addind a temporarely database that stores my sessions value
  • Martin Lingstuyl 202 posts 379 karma points
    Dec 21, 2010 @ 16:35
    Martin Lingstuyl
    By the way. This conversation was some time ago, but the approach of runallmanagedmodules does not work.
    Does anyone know what does?
  • aghy 129 posts 308 karma points
    Dec 21, 2010 @ 16:59
    aghy
    Hi Martin,
    Take a look at this I had the problem of not being able to access the session from /base when using umbraco 4.0.3. After a bit of searching I found a fix.
    I have since started using 4.5.2 and its much better especially the new way of doing xslt.
    Ben
