  • Corné Strijkert 80 posts 456 karma points c-trib
    Dec 16, 2015 @ 11:07
    Corné Strijkert
    alt template url does not work when using 404 content finder
    Hi all,
    I want to write
    /sitemap?altTemplate=xmlsitemap
    as follow:
    /sitemap/xmlsitemap
    But, i have also writed a custom 404 content finder. When i enable this content finder the '/sitemap/xmlsitemap' does not work, but when i disable the custom content finder it's ok.
    What should i do to fix this?
    Dec 17, 2015 @ 09:25
    Marc Goodson
    Hi Corné
    How are you registering your custom 404 finder ?
    is it registered as a 'ContentLastChanceFinder' ?
    or
    are you adding it as a ContentFinderResolver ?
    https://our.umbraco.org/documentation/Reference/Routing/Request-Pipeline/IContentFinder
    if you've added it to the list of ContentFinderResolvers, have you added it 'above' the IContentFinder that looks for alternative templates ? ie your custom 404 finder is firing before the alt template one ?
    regards
    Marc
