Richtext editor has as standard support for Embed.
LeBlender controller Tabs works perfectly, and more than only text may be separated into tabs, also eg youtube videos.
(Umbraco backoffice):
(Frontview):
But what if I want support for other types of controllers eg Modal and Iframe (Iframe, also functioning with Google Maps/Google My Maps, which standard Embed editor not does) - two editors I created with LeBlender package 1.0.8.3?
I have tried something of inserting macro into Richtext editor (RTE), but didn't succeed so far since I don't know how LeBlender controls can be changed to macros, and has therefore thought out another method, which might be a little more obvious to the user.
Can data type Richtext editor be expanded to also support the two LeBlender controllers Modal and Iframe?
This is something I really want to work, and I don't see how this can be done in other ways. Does anyone have a solution?
Nested LeBlender control / modifying richtext editor
I've made a Tabs LeBlender controller,
which uses content with richtext editor (RTE).
(Frontview):
Can I use Archetype package for this task, and if - how?
https://our.umbraco.org/projects/backoffice-extensions/archetype/
