  • Bagus Adiyanto 4 posts 34 karma points
    Feb 26, 2010 @ 21:17
    Bagus Adiyanto
    Insert Flash File does not work
    Install InsertFlashFile package and I upload the swf succesffully. however when I play it in my webpage it display the plugin but the movie won't play. anyone has this kind of experience before ?
    thanks
    Mar 02, 2010 @ 13:00
    dandrayne
    Hi Baqus
    Which insert flash project are you using?  If it's http://our.umbraco.org/projects/insert-flash-file, then perhaps I can help.
    What version of swfobject is in your /scripts/ folder?
    Dan
  • Ranjit J. Vaity 66 posts 109 karma points
    Mar 02, 2010 @ 16:14
    Ranjit J. Vaity
    Hi Baqus,
    Type providing the flash code chunk in here, we can take a look.
    Else
    Try using fiddler HTML traffic debugging tool: http://www.fiddler2.com. Any request that causing problem or bad request will show up in red.
    Regards.
    Ranjit J. Vaity
  • Mark Furmanek 2 posts 22 karma points
    Sep 30, 2010 @ 23:28
    Mark Furmanek
    Dan, I'm having the same problem as Baqus.
    swfobject.js ver. 2.2
    Whenever the page renders, the path to the video is empty.
    Viewing the source code on the Content page yields this after the video is inserted:
    <div umb_videoheight="315" umb_macroalias="InsertFlashFile" umb_videoid="Bankruptcy2" umb_settingsnode="/media/1275/bankruptcy.swf" umb_videowidth="400" ismacro="true" onresizestart="return false;" umbversionid="99a0a66d-653e-4391-9eba-5d399b86bac0" umbpageid="1266" title="This is rendered content from macro" class="umbMacroHolder"><!-- startUmbMacro -->
    <span>No macro content available for WYSIWYG editing</span><!-- endUmbMacro -->
    When the code renders in the browser (FF / IE / etc.), this is what the source code reveals:
    <div id="Bankruptcy2">
    <strong>  </strong>
    <p><strong><a href="http://www.macromedia.com/go/getflashplayer">Get the Flash Player</a> to see this content.</strong></p>
    <script src="/scripts/swfobject.js" type="text/javascript"></script>
    var path = "";
    var videowidth = "400";
    var videoid = "Bankruptcy2";
    var videoheight = "315";
    var flashvars = {};
    var attributes = {};
    var params = {
      wmode: "transparent",
      allowfullscreen: "true",
      allscriptaccess: "always"
    swfobject.embedSWF(path, videoid, videowidth, videoheight, "9.0.0", flashvars, params, attributes);
    </script>
    As you can see, the first var "path" is empty, which is probably why the movie doesn't appear on the page.
    The XSLT (InsertFlashFile.xslt) that was installed is:
    <!DOCTYPE xsl:Stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
    <xsl:output method="html" omit-xml-declaration="yes"/>
    <xsl:variable name="videonode" select="/macro/SettingsNode"/>
    <xsl:variable name="videoid" select="umbraco.library:Replace(/macro/videoid,' ','')"/>
    <xsl:variable name="videopath" select="$videonode/node/data[@alias='umbracoFile']"/>
    <xsl:variable name="videoheight" select="/macro/VideoHeight"/>
    <xsl:variable name="videowidth" select="/macro/VideoWidth"/>
    <xsl:template match="/">
    <div>
      <xsl:attribute name="id">
        <xsl:value-of select="$videoid" />
      </xsl:attribute>
      <p><a href="http://www.macromedia.com/go/getflashplayer">Get the Flash Player</a> to see this content.</p>
    <script type="text/javascript" src="/scripts/swfobject.js"></script>
    <![CDATA[
    var path = "]]><xsl:value-of select="$videopath" /><![CDATA[";
    var videowidth = "]]><xsl:value-of select="$videowidth" /><![CDATA[";
    var videoid = "]]><xsl:value-of select="$videoid" /><![CDATA[";
    var videoheight = "]]><xsl:value-of select="$videoheight" /><![CDATA[";
    var flashvars = {};
    var params = {
    </script>
    </xsl:template>
    </xsl:stylesheet>
    The four parameters on the InstallFlashFile macro are:
    SettingsNode - Choose Video - mediaCurrent
    videoid - Video ID (unique, no special chars) - text
    VideoWidth - Width - number
    VideoHeight - Height - text
    Any help that you can give would be greatly appreciated.
    Mark
