I am version 7.3 and I saw that Vorto is 75% at that version. Can I still use that version or should I build it from the latest source? I have never done this before, so if someone has, would you kindly walk me through it so I can get it working with 7.3.
Building Vorto from source to work with 7.3
Thanks a bunch, Saied
You should try Vorto 1.5 that should work a 100%.
https://our.umbraco.org/projects/backoffice-extensions/vorto
Jeroen
Ah Jeroen,
My friend, thanks a lot. I didn't even notice that. I just saw 7.3 (75%).
Do you know if I install it through the package installer in Umbraco, does it grab 1.5 or do I have to locally install it?
I'm not sure if the package installar is updated but NuGet has the latest: https://www.nuget.org/packages/Our.Umbraco.Vorto/1.5.0
Jeroen
Great.
Thanks Jeroen.
