  • Anders Dahl Tollestrup 73 posts 52 karma points
    Mar 24, 2010 @ 08:10
    Visual Studio 2010 brakes the reference to umbraco.dll
    Hi out there
    It has been a while since I last had developed umbraco user controls, and in the mean time I have upgraded to Visual Studio 2010. Now it seems like VS brakes the reference to the umbraco.dll. What I experience is:
    • When add the reference, I can browse through umbraco.presentation.nodefactory, but after a solution build my VS can find the umbraco namespace
    Have any of you experienced that ?? (I run umbraco 4.0.3)
    Kind regards
    /Anders
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Mar 24, 2010 @ 09:50
    Richard Soeteman
    Hi Anders,
    Think a lot of community users are using vs2010 already. Do you use compatibility mode? If not, you shopuld I gues..
    Richard
  • Aaron Powell 1708 posts 3046 karma points c-trib
    Mar 24, 2010 @ 11:37
    Aaron Powell
    What version of .NET are you running, 2, 3 or 3.5?
    All projects we're working on at The FARM these days are 2010 projects, with them almost all being Umbraco.
    Mar 24, 2010 @ 14:53
    Hi Richard
    I'm properly not running in compatibility mode. I'll just check that out.
    /Anders
    Mar 25, 2010 @ 13:11
    Hi all
    Just an update on my experience on the broken reference problem in Visual Studio 2010.
    I was running on the old Visual Studio 2010 Beta 2, which didn't have all error messages in place. After upgrading to the new RC version of Visual Studio 2010, I found out that my project was targeting to a wrong .NET framework. I thought that the umbraco dll's was compiled to .NET Framework 2.0, but after changing target to .NET Framework 3.5 everything was compiling just fine and no broken references.
    Kind regards
    /Anders
  • Ranjit J. Vaity 66 posts 109 karma points
    Mar 25, 2010 @ 15:56
    Ranjit J. Vaity
    Even I have experienced breaking of references. In these cases, I maintained a separate copy of .dll files in separate folder called "SharedBinaries" and I use to place my references to assemblies in this folder rather in bin folder. And all worked good.
    Hope this helps!!
    Regards,
    Ranjit J. Vaity
  • praveen 113 posts 164 karma points
    Jul 21, 2011 @ 04:28
    praveen
    HI I have installed umbraco 4.7
    from the install pacakage I have taken the umbraco.dll 1.0.4090.38017 and referenced it in visual studio 2010 project,  I then wrote the follwiing code to loop through the Parent and its child nodes:
             Node CurNode = Node.GetCurrent();
             Nodes ChNodes = CurNode.Children;
             string text = null;
                foreach (Node doc in ChNodes)
                    if (doc.Children.Count > 1)
                        text += doc.Name + "--";
                Label1.Text = text;
    when I compile the project in VS2010 I get the following error:
    Error 1 The type 'umbraco.interfaces.INode' is defined in an assembly that is not referenced. You must add a reference to assembly 'interfaces, Version=1.0.4085.20549, Culture=neutral, PublicKeyToken=null'. C:\Software Development\trunk\UserControls\DocumentList.ascx.cs 57 13
    How do I get rid of this error
    Basically I want to read the document properties in csharp code and write it to format to diplay
    you help is greatly appreciated
    Kind Regards
    Praveen
