  • Ivan 139 posts 302 karma points
    Jun 25, 2010 @ 14:39
    Ivan
    Please Help!! XSLT Parameter is driving me crazy
    Hi.
    I am doing a simple test for checking that Macro parameters are correctly parsed in my Umbraco 4.0.3 installation.
    Problem is no matter how many tests i do, macro parameter is never parsed.
    XSLT Code (Prueba.xslt)
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
    <xsl:variable name="parametro" select="/macro/parametro"/>
    <xsl:template match="/">
    Value of parameter is: <xsl:copy-of select="/macro/parametro"/>
    <br />
    Value of parameter is: <xsl:value-of select="$parametro"/>
    </xsl:template>
    </xsl:stylesheet>
    Macro Prueba (Alias = Prueba, use Prueba.xslt as xslt file) parameters defined
    Alias (parametro) Name (parametro) Type (text)
    Macro used in testing template
    <%@ Master Language="C#" MasterPageFile="/umbraco/masterpages/default.master" AutoEventWireup="true" %>
    <asp:Content ContentPlaceHolderID="ContentPlaceHolderDefault" runat="server">
        <umbraco:Macro parametro="'Prueba'" Alias="Prueba" runat="server"></umbraco:Macro>
    </asp:Content>
    Results
    I am supposed to get following text as a result of use the macro: "Value of parameter is: Prueba".
    Fact is am getting nothing and that is driving me crazy.
    What am i doing wrong? Maybe my Umbraco installation is not working properly?
    Thanks a lot for your Help!!
    Ivan
  • Pat O'Callaghan 34 posts 56 karma points
    Jun 26, 2010 @ 03:33
    Pat O'Callaghan
    Are you getting nothing at all or are you getting just "Value of parameter is:" with no "Prueba" value? in other words is the macro being called or not at all?
  • Nigel Wilson 945 posts 2077 karma points
    Jun 26, 2010 @ 08:10
    Nigel Wilson
    Have you declared the parameters in the macro under "Devloper" - "Macros" - "The name of your macro" - Parameters tab ?
    Jun 26, 2010 @ 12:49
    Ivan
    Thanks a lot guys!! My code was ok. Reinstalling Umbraco fixed the problem.
