  • Scott Campbell 4 posts 24 karma points
    Jun 25, 2010 @ 16:37
    Scott Campbell
    GetXmlDocumentByUrl help
    Over the last few days I have been trying to work out how to bring a World of Warcraft armory feed into my site but without success. I'm not sure if it is because the format is wrong or I am doing it wrong, but I am unable to pull any information from the nodes. Running the same code (with changed node names) on other RSS feeds seems to work, can anyone tell me why I can't pull information from nodes from this feed.
    An example feed can be viewed here:
    http://www.wowarmory.com/character-feed.atom?r=Dreadmaul&cn=Crunchballs&locale=en_US
    My XSLT is here:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
     version="1.0"
    <xsl:template match="/">
    <!-- start writing XSLT -->
    <xsl:for-each select="$currentPage/ancestor-or-self::root//node [@nodeTypeAlias='Feed Item']">
      <xsl:variable name="url" select="string(data[@alias='url'])" />
      <!-- Is the url populated? -->
      <xsl:if test="string-length($url) &gt; 0">
        <xsl:variable name="feedContent" select="umbraco.library:GetXmlDocumentByUrl( $url )"/>
        <xsl:value-of select="$feedContent/feed/author/name"/>
    <xsl:for-each select="exsl:node-set($feedContent)//entry">
        <xsl:value-of select="title"/>
    </xsl:for-each>
      </xsl:if>
    </xsl:for-each>
    </xsl:template>
    </xsl:stylesheet>
    Jun 25, 2010 @ 17:21
    Scott Campbell
    As soon as I post up an this request I manage to find the reason and a solution. Why couldn't I have found this with all the searching I had done earlier.
    http://our.umbraco.org/forum/developers/xslt/8016-getXMLDocument-won't-display-any-content
