  • nielsrobin 5 posts 22 karma points
    Jul 01, 2010 @ 15:55
    nielsrobin
    Having trouble using variable from macro
    So i built a simpel slideshow macro (code below). Which all works great except for one detail. I'm not using my "source" variable to get the right folder in the media library. The problem is when i try to, that is replace "1198" with "$source", it says: "System.OverflowException: Value was either too large or too small for an Int32."
    The weird think is that i'm using it in the line above "s{$source"}" .. were it correctly returns "s1198". What am i doing wrong, since it doesn't want to recognize my variable as an Int32?
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
        version="1.0"
    <xsl:variable name="source" select="/macro/source"/>
    <xsl:template match="/">
    <div class="slideshow s{$currentPage/@id} s{$source}">
    <xsl:for-each select="umbraco.library:GetMedia(1198, 'false')/node">
       <xsl:choose>
         <xsl:when test="umbraco.library:GetMedia(@id, 'false')/data [@alias = 'umbracoFile']">
            <img src="{umbraco.library:GetMedia(@id, 'false')/data [@alias = 'umbracoFile']}" alt="{@nodeName}" />
         </xsl:when>
         <xsl:otherwise>
          <!--Do something with the directory-->
         </xsl:otherwise>
        </xsl:choose>
    </xsl:for-each>
    </xsl:template>
    </xsl:stylesheet>
    Jul 01, 2010 @ 15:56
    Jul 01, 2010 @ 16:06
    nielsrobin
    Wrapping
    <xsl:if test="$source != '' ">
    </xsl:if>
    around did the trick. Thanks Rich.
