That's definitely a bug - it makes no sense to use CDATA for that (will probably be fixed with an update soon).
That said, you will have to find a way to do it - I've seen several topics in the forums where parsing CDATA was a problem. I'd suggest you search for one of them and see if someone (probably the mighty Lee Kelleher :-) created an extension to convert a CDATA Section to a nodeset.
Just so you know: There's no amount of XSLT 1.0 pokery-jiggery that'll make you do it. Must find an extension.
Just had this issue as well. I thought it had been fixed, as I couldn't see the CDATA in the XML i wrote out from a copy-of in a textarea. But I couldn't figure out why my iteration through the selected node id's didn't work. So I took a look in the database, and here I also saw the CDATA. But I gues it'll be fixed in the future versions of this great datatype :)
Actually I just wanted to say thanks for the code snippet guys ;)
Daniel, glad you got it resolved. I'll speak to Shannon about the CDATA issue (when he gets back from holiday).
As for the C# snippet in your XSLT - I wouldn't recommend doing it that way - there are major performance issues by doing that. Each time the page is loaded, the code is executed at runtime and stored as a file in the "Temporary ASP.NET Files" folder - so depending on the traffic of your website, it could start to fill up your disk-space quite quickly.
The better approach is to move the snippet to its own DLL and reference it as an XSLT extension.
You're welcome. I used to use inline C# code in my XSLTs all the time, until Benjamin Howarth told me about the Temp ASP.NET folder - which he found out during his Medium Trust development - also that inline XSLT code doesn't work in Medium Trust - that's Full Trust only!
Help parsing selected nodes from Multi-Node tree picker
I have the multi-node tree picker datatype working and can select nodes.
The problem is reading the selected nodes to display links on a page.
After looking at the database, I noticed that selected nodes are store as CDATA
<headerNodes>
<![CDATA[
<MultiNodePicker>
<nodeId>1092</nodeId>
<nodeId>1094</nodeId>
<nodeId>1093</nodeId>
<nodeId>1099</nodeId>
</MultiNodePicker>
</headerNodes>
How can I parse this and display links on my page?
Hi Daniel,
/Chriztian
I figured I would have to use an extension. I'll see what I can find until the bug is fixed.
Thanks!
Hi Daniel,
In case you haven't found it yet, this should do the trick:
public static XPathNodeIterator parse(string data) {if(data==null || data.Length==0) {XPathExpression xPathExpression = xPathNavigator.Compile("/");Cheers,
Sascha
Looks like it should work great.. I'll give it a go and let you know.
Worked like a charm.. THANK YOU. Here is the final XSLT.
<!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp " ">]>
<xsl:stylesheet
version="1.0"
xmlns:local="http://local"
xmlns:umbraco.library="urn:umbraco.library">
<msxml:script implements-prefix="local" language="C#">
//<![CDATA[
public XPathNodeIterator parse(string data) {
data="<Empty />";
System.IO.StringReader stringReader = new System.IO.StringReader(data);
XPathDocument xPathDocument = new XPathDocument(stringReader);
XPathNavigator xPathNavigator = xPathDocument.CreateNavigator();
XPathNodeIterator xPathNodeIterator = xPathNavigator.Select(xPathExpression);
return xPathNodeIterator;
</msxml:script>
<xsl:template match="/">
<xsl:variable name="nodes" select="local:parse($currentPage/ancestor-or-self::* [headerNodes != ''] [1] /headerNodes)"/>
<ul>
<xsl:for-each select="$nodes/MultiNodePicker/nodeId">
<li>
<xsl:if test="position() = 1">
<xsl:attribute name="class">first</xsl:attribute>
</xsl:if>
<a>
<xsl:attribute name="href">
<xsl:value-of select="umbraco.library:NiceUrl(.)"/>
</xsl:attribute>
<xsl:value-of select="umbraco.library:GetXmlNodeById(.)/@nodeName"/>
</a>
</li>
</xsl:for-each>
</ul>
</xsl:template>
</xsl:stylesheet>
/Kim A
Cheers, Lee.
I'll do that now.. don't want to have issues later down the line.. Thanks!
Anyway, you live and learn! :-D
Cheers, Lee.
