I cannot get GetMedia working in an XSLT macro when using the 4.5 release with the legacy schema.
Here's my code:
<xsl:value-of select="umbraco.library:GetMedia(1070, 0)/data [@alias='umbracoFile']" />
Where 1070 is a Media item of type Image. The code returns nothing.
Any ideas???
Hi Matthew,
Try adding the node name to the XPath...
<xsl:value-of select="umbraco.library:GetMedia(1070, 0)/node/data[@alias='umbracoFile']" />
or failing that, try using the nodeTypeAlias (from the new schema - this is guesswork).
<xsl:value-of select="umbraco.library:GetMedia(1070, 0)/Image/data[@alias='umbracoFile']" />
Good luck!
Cheers, Lee.
Lee,
You nailed it! Thanks so much.
Matt
Upload image
GetMedia problems with legacy schema in Umbraco 4.5
Here's my code:
Any ideas???
Hi Matthew,
Good luck!
Cheers, Lee.
Lee,
Matt
