Hi All. I am having problem to select only first level child nodes. Could anyone give me some idea?
Thank you
Hey,
Do you want to post the code you have and we can see where things are going wrong?
Matt
Hi lingjing,
You could start with this and tweak it to your liking (it's compatible with the XML format of 4.0 as well as 4.5):
<xsl:variable name="level1" select="$currentPage/ancestor-or-self::*[@level = 1]" /> <xsl:template match="/"> <xsl:apply-templates select="$level1/node" /> <xsl:apply-templates select="$level1/*[@isDoc]" /> </xsl:template> <xsl:template match="node | *[@isDoc]"> <p> <xsl:value-of select="@nodeName" /> </p> </xsl:template>
/Chriztian
Thanks Chriztiain. you solved my problem
How to only select first level node?
Thank you
Hey,
Matt
Hi lingjing,
<xsl:variable name="level1" select="$currentPage/ancestor-or-self::*[@level = 1]" /> <xsl:template match="/"> <xsl:apply-templates select="$level1/node" /> <xsl:apply-templates select="$level1/*[@isDoc]" /> </xsl:template> <xsl:template match="node | *[@isDoc]"> <p> <xsl:value-of select="@nodeName" /> </p> </xsl:template>/Chriztian
