  • Rik Helsen 670 posts 873 karma points
    Jul 22, 2010 @ 20:01
    Rik Helsen
    creating multi-level navigation in 4.5 schema
    I'm having some issues getting multiple level navigation to work with the new xml schema, has anyone got a working example ready?
    in the end i would like this to be able to work with a sourcenode to start iterating from, and respecting umbraconavihide...
    This is the code that I am using now, but it doesn't go into levels, and doesn't return all nodes but only 1 document type for some reason...
    <!DOCTYPE xsl:stylesheet [
    <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet version="1.0"
    xmlns:msxsl="urn:schemas-microsoft-com:xslt"
    xmlns:netaddicts-be="urn:netaddicts-be:xslt"
    exclude-result-prefixes="msxml umbraco.library netaddicts-be">
    <!-- Holds the start node for the navigation. Optional -->
    <xsl:param name="startNodeId" select="/macro/startNodeId"/>
    <!-- Holds number of sublevels to generate. Macro parameter is optional. Defaults to one if not supplied -->
    <xsl:param name="maxDrilldownLevel" select="netaddicts-be:ReadMacroParameter(//macro/maxLevels,'1')"/>
    <xsl:template match="/">
    <!-- Check whether a start node has been supplied -->
    <xsl:choose>
    <xsl:when test="$startNodeId != ''">
    <!-- Start building the top navigation from the node supplied by start node id -->
    <xsl:call-template name="buildTopNavigation">
    <xsl:with-param name="navigationNodes" select="umbraco.library:GetXmlNodeById($startNodeId)"/>
    </xsl:call-template>
    </xsl:when>
    <xsl:otherwise>
    <!-- Start building navigation from top level node -->
    <xsl:with-param name="navigationNodes" select="umbraco.library:GetXmlAll()"/>
    </xsl:otherwise>
    </xsl:choose>
    </xsl:template>
    <!-- Start building the top navigation (first level navigation) -->
    <xsl:template name="buildTopNavigation">
    <xsl:param name="navigationNodes"/>
    <ul class="mainNav">
    <!-- Iterate child nodes -->
      <xsl:for-each select="$navigationNodes/child/* [@isDoc]">
    <!-- Create var for easier reading/processing -->
    <xsl:variable name="currentProcessedNode" select="."/>
    <xsl:variable name="currentLevel" select="0"/>
    <!-- Check whether node should be visible in first level navigation -->
    <xsl:if test="string($currentProcessedNode/umbracoNaviHide) != '1'">
    <li>
    <!-- Build the navigation link using the node currently being processed in the for-each loop -->
    <xsl:call-template name="buildLink">
    <xsl:with-param name="node" select="$currentProcessedNode"/>
    <!-- Build next level navigation only if applicable -->
    <!-- Still need to check whether all child nodes have been set to umbracoHideChildren = 1 whereas umbracoNaviHide = 0
    this case would yield an empty ul element -->
    <xsl:if test="(count($currentProcessedNode/node) &gt; 0)
    and (string($currentProcessedNode/umbracoHideChildren) != '1')
    and ($currentLevel &lt; $maxDrilldownLevel)">
    <xsl:call-template name="buildNavigation">
    <xsl:with-param name="parentNode" select="$currentProcessedNode"/>
    <xsl:with-param name="level" select="$currentLevel + 1"/>
    </xsl:if>
    </li>
    </xsl:if>
    </xsl:for-each>
    </ul>
    </xsl:template>
    <!-- A template used for building the non top navigation tree -->
    <xsl:template name="buildNavigation">
    <xsl:param name="parentNode"/>
    <xsl:param name="level"/>
    <ul>a
    <!-- Iterate over the child nodes-->
    <xsl:for-each select="$parentNode/* [@isDoc]">
    <!-- Check whether node should be processed -->
    <li class="child">
    <!-- Build the navigation link -->
    <!-- Build next level navigation only if applicable; recursive call -->
    <xsl:if test="
    and ($level &lt; $maxDrilldownLevel)">
    <xsl:with-param name="level" select="$level + 1"/>
    </xsl:if>
    </li>
    </xsl:if>
    </xsl:for-each>
    </ul>
    </xsl:template>
    <!-- A template that builds our navigation link based on node properties -->
    <xsl:template name="buildLink">
    <xsl:param name="node"/>
    <xsl:choose>
    <!-- Build link to external page -->
    <xsl:when test="string($node/externalURL) != ''">
    <xsl:call-template name="buildExternalLink">
    <xsl:with-param name="node" select="$node"/>
    </xsl:when>
    <!-- Build link for redirecting to a custom supplied url -->
    <xsl:when test="string($node/umbracoRedirect) != ''">
    <xsl:call-template name="buildRedirectLink">
    </xsl:when>
    <!-- Default link builder -->
    <xsl:otherwise>
    <xsl:call-template name="buildNormalLink">
    </xsl:otherwise>
    </xsl:choose>
    </xsl:template>
    <!-- A template that builds a link to an external page -->
    <xsl:template name="buildExternalLink">
    <xsl:call-template name ="outputNode">
    <xsl:with-param name="currentNode" select="$* [@isDoc]"/>
    <a>
    <!-- Set the href attribute -->
    <xsl:attribute name="href">
    <xsl:value-of select="$node/externalURL"/>
    </xsl:attribute>
    <!-- Set the target attribute if available from the properties -->
    <xsl:if test="string($node/externalTarget) != ''">
    <xsl:attribute name="target">
    <xsl:value-of select="$node/externalTarget"/>
    </xsl:attribute>
    </xsl:if>
    <!-- Set the title attribute if available from the properties -->
    <xsl:if test="string($node/navTooltip) != ''">
    <xsl:attribute name="title">
    <xsl:value-of select="string($node/navTooltip)"/>
    </xsl:attribute>
    </xsl:if>
    <!-- Set actual text for the link, either available from the properties or just plain umbraco link-->
    <xsl:choose>
    <xsl:when test="string($node/navText) != ''">
    <xsl:value-of select="string($node/navText)"/>
    </xsl:when>
    <xsl:otherwise>
    <xsl:value-of select="$node/@nodeName"/>
    </xsl:otherwise>
    </xsl:choose>
    </a>
    </xsl:template>
    <xsl:template name="buildRedirectLink">
    <a>
    <!-- Set the href attribute based on the redirect supplied -->
    <xsl:value-of select="netaddicts-be:FixLink(string($node/umbracoRedirect))"/>
    </xsl:attribute>
    </xsl:attribute>
    </xsl:if>
    <xsl:choose>
    </xsl:when>
    <xsl:otherwise>
    </xsl:otherwise>
    </xsl:choose>
    </a>
    </xsl:template>
    <xsl:template name="buildNormalLink">
    <a>
    <!-- Set the href attribute, either the alias if available, else use NiceUrl() -->
    <xsl:choose>
    <xsl:when test="string($node/umbracoUrlAlias) != ''">
    <xsl:value-of select="netaddicts-be:FixLink(string($node/umbracoUrlAlias))"/>
    </xsl:when>
    <xsl:otherwise>
    <xsl:value-of select="umbraco.library:NiceUrl($node/@id)"/>
    </xsl:otherwise>
    </xsl:choose>
    </xsl:attribute>
    </xsl:attribute>
    </xsl:if>
    <xsl:choose>
    </xsl:when>
    <xsl:otherwise>
    </xsl:otherwise>
    </xsl:choose>
    </a>
    </xsl:template>
    <!-- For debugging purposes, writes out all relevant node properties -->
    <xsl:template name="outputNode">
    <xsl:param name="currentNode"/>
    <ul>
    <li>
    @id=<xsl:value-of select="$currentNode/@id"/>
    </li>
    <li>
    @nodeName=<xsl:value-of select="$currentNode/@nodeName"/>
    </li>
    <li>
    @umbracoNaviHide=<xsl:value-of select="$currentNode/umbracoNaviHide"/>
    </li>
    <li>
    @umbracoHideChildren=<xsl:value-of select="$currentNode/umbracoHideChildren"/>
    </li>
    <li>
    @navText=<xsl:value-of select="$currentNode/navText"/>
    </li>
    <li>
    @navTooltip=<xsl:value-of select="$currentNode/navTooltip"/>
    </li>
    <li>
    @externalURL=<xsl:value-of select="$currentNode/externalURL"/>
    </li>
    <li>
    @externalTarget=<xsl:value-of select="$currentNode/externalTarget"/>
    </li>
    <li>
    @umbracoRedirect=<xsl:value-of select="$currentNode/umbracoRedirect"/>
    </li>
    <li>
    @umbracoUrlAlias=<xsl:value-of select="$currentNode/umbracoUrlAlias"/>
    </li>
    </ul>
    </xsl:template>
    <msxsl:script language="C#" implements-prefix="netaddicts-be">
    <![CDATA[
    //Function is taken from XSLTSearch by Douglas Robar from Percipient Studios (http://www.percipientstudios.com/)
    public string ReadMacroParameter(string value, string defaultValue) {
    if (value == "")
    return defaultValue;
    else
    return value.Replace(" ", "");
    //Function fixes a possible wrongly formatted link
    public string FixLink(string oldLink) {
    string newLink = string.Empty;
    if (!oldLink.StartsWith("/"))
    newLink += "/";
    newLink += oldLink;
    if (!oldLink.EndsWith(".aspx"))
    newLink += ".aspx";
    return newLink;
    </msxsl:script>
    </xsl:stylesheet>
  • Jeff Grine 149 posts 189 karma points
    Jul 22, 2010 @ 21:40
    Jeff Grine
    I haven't tried this yet, but it seems like this line should be the problem
    Have you tried
    <xsl:for-each select="$navigationNodes/* [@isDoc]">
    Jul 22, 2010 @ 22:11
    Rik Helsen
    I've removed a lot of the complicated xslt and ended up with this:
    xmlns:umbraco.library="urn:umbraco.library">
    <xsl:output method="xml" />
    <xsl:param name="maxDrilldownLevel" select="/macro/maxLevels"/>
      Startnode: <xsl:value-of select="$startNodeId"/><br />
    MAxlevel: <xsl:value-of select="$maxDrilldownLevel"/><br />
    <xsl:choose>
    </xsl:when>
    <xsl:otherwise>
    </xsl:otherwise>
    </xsl:choose>
    </xsl:template>
    NAvigationnodes: <xsl:value-of select="$navigationNodes"/>
        a
        <li>
    <xsl:if test="(count($currentProcessedNode/node) &gt; 0) and ($currentLevel &lt; $maxDrilldownLevel)">
    </xsl:if>
    </li>
    </xsl:if>
    </xsl:for-each>
    </ul>
    </xsl:template>
    <ul>a
    <li class="child">
    <xsl:if test="
    </xsl:if>
    </li>
    </xsl:if>
    </xsl:for-each>
    </ul>
    </xsl:template>
    </xsl:call-template></xsl:template>
    <a>
    <xsl:value-of select="umbraco.library:NiceUrl($node/id)"/>
    </xsl:attribute>
    <xsl:choose>
    </xsl:when>
    <xsl:otherwise>
    <xsl:value-of select="$node/nodeName"/>
    </xsl:otherwise>
    </xsl:choose>
    </a>
    </xsl:template>
    </xsl:stylesheet>
    But now i get this error when saving:
    Error occured
    System.OverflowException: Value was either too large or too small for an Int32.
    at System.Convert.ToInt32(Double value)
    at System.Double.System.IConvertible.ToInt32(IFormatProvider provider
    at System.Convert.ChangeType(Object value, Type conversionType, IFormatProvider provider)
    at System.Xml.Xsl.Runtime.XmlQueryRuntime.ChangeTypeXsltArgument(XmlQueryType xmlType, Object value, Type destinationType)
    at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
    at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, XPathNavigator node)
    at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime, IList`1 navigationNodes)
    at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Execute(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument,
    XmlResolver dataSources, XsltArgumentList argumentList,
    XmlSequenceWriter results)
    XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter
    writer)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable
    input, XsltArgumentList arguments, XmlWriter results, XmlResolver
    documentResolver)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String
    fileName, String oldName, String fileContents, Boolean ignoreDebugging)
    Jul 22, 2010 @ 22:19
    Jeff Grine
    So you're passing an extension expecting an int a bad value. Maybe here
    Should be @id instead? Might be time for the debugger to see which line is throwing the exception.
    Jul 22, 2010 @ 22:26
    Rik Helsen
    Jeff: are you sure? that's not what I conclude from these examples: http://our.umbraco.org/wiki/reference/xslt/45-xml-schema/xslt-examples-updated-to-new-schema
    Jul 22, 2010 @ 22:31
    Jeff Grine
    Yes, id is still an attribute of whatever element you have in the node variable, so you access it with '@'. I can see where that document might have gotten you though. NodeTypeAlias used to be an attribute of the data element, so you had to do 'data [@nodeTypeAlias='whatever']'. That one attribute is now an element and that was the big change (and a very nice one). Other attributes are still attributes though, so need the @.
    Jul 27, 2010 @ 11:15
    Rik Helsen
    To create this navigation:
    I finally came up with this xslt:
    <!DOCTYPE xsl:stylesheet [ <!ENTITY nbsp "&#x00A0;"> ]>
    <xsl:stylesheet
      version="1.0"
    umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes
    Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings
    Exslt.ExsltSets "
    <!-- Input the documenttype you want here -->
    <xsl:variable name="level" select="2"/>
    <!-- The fun starts here -->
      <xsl:for-each select="$currentPage/ancestor-or-self::* [@level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
        <xsl:if test="$currentPage/@id = current()/@id or $currentPage/../@id = current()/@id or $currentPage/../../@id = current()/@id">
          <!-- output navigation Title -->
          <a class="leftnavtitle" href="{umbraco.library:NiceUrl(@id)}">
          </a>
          <ul>
            <!-- 1st navigation items -->
            <xsl:for-each select="./child::* [@isDoc and string(umbracoNaviHide) != '1']">
              <xsl:if test="$currentPage/ancestor-or-self::node/@id = current()/@id"></xsl:if>
              <li>
                   <xsl:if test="@id = $currentPage/@id"><xsl:attribute name="class">selected</xsl:attribute></xsl:if>
                </a>
              <!--output 2nd level nevigation items -->
                <xsl:if test="count(current()/child::*
    [@isDoc]) &gt; 0 and $currentPage/@id = current()/@id or
    current()/@id"
                  <ul>
                    <!--output 3rd level nevigation items -->
                    <li>
                      </a>
                    </li>
                    </xsl:for-each>
                  </ul>
                </xsl:if>
                <!--end of 4th level children -->
                </li>
              </xsl:for-each>
            </ul>
          </xsl:if>
        </xsl:for-each>
    </xsl:template>
    </xsl:stylesheet>
  • MartinB 411 posts 512 karma points
    Jun 13, 2011 @ 21:29
    MartinB
    Thank you Rik!
    I needed:
    and $currentPage/@id = current()/@id or $currentPage/../@id = current()/@id or $currentPage/../../@id = current()/@id"
    For my level 2 check, awesome!
