hello guys,
i want to create macro that display the most commented posts (the most popular, only the top 5).
i know how to count comments for posts:
<xsl:variable name="numberofcomments" select="count(BlogLibrary:GetCommentsForPost($post/@id)//comment)"/>
i know how to loop on 5 posts:
<ul id="popular-posts"> <xsl:for-each select="$currentPage/ancestor-or-self::node//node [string(data [@alias='umbracoNaviHide']) != '1' and @nodeTypeAlias='BlogPost']"> <xsl:sort select="@createDate" order="descending" /> <xsl:if test="position()<= 5"> <li> <xsl:variable name="text" select="umbraco.library:StripHtml(./data[@alias='bodyHeader'])" /> <a href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="umbraco.library:TruncateString($text,50,'...')" disable-output-escaping="yes"/></a> </li> </xsl:if> </xsl:for-each></ul>
but i dont know how to connect the dots..
Thanks!
Hi eran,
You should be able to just use the number of comments as the sort option:
<xsl:sort select="count(BlogLibrary:GetCommentsForPost(@id)//comment)" data-type="number" order="descending" />
/Chriztian
EDIT 2013-10-04: Added the data-type attribute which is needed to get the sorting correct.
Thanks, i will check it soon as possible (and will not forget to mark the solution).
Eran.
Can you please share your final solution to this? I am also trying to get this to work on my blog.
@Alexandru I've updated my answer to include the missing data-type attribute
Cheers!
Howto Display most Popular posts?
hello guys,
Thanks!
Hi eran,
/Chriztian
Eran.
/Chriztian
Cheers!
