<feed xmlns:google="http://base.google.com/ns/1.0" xml:lang="en-US" xmlns:openSearch="http://a9.com/-/spec/opensearch/1.1/" xmlns="http://www.w3.org/2005/Atom" xmlns:twitter="http://api.twitter.com/">
<id>tag:search.twitter.com,2005:search/umbraco</id>
<link type="text/html" href="http://search.twitter.com/search?q=umbraco" rel="alternate"/>
<link type="application/atom+xml" href="http://search.twitter.com/search.atom?lang=all&q=umbraco" rel="self"/>
<title>umbraco - Twitter Search</title>
<link type="application/opensearchdescription+xml" href="http://search.twitter.com/opensearch.xml" rel="search"/>
<link type="application/atom+xml" href="http://search.twitter.com/search.atom?lang=all&q=umbraco&since_id=21479337184" rel="refresh"/>
<twitter:warning>since_id removed for pagination.</twitter:warning>
<updated>2010-08-18T10:22:13Z</updated>
<openSearch:itemsPerPage>15</openSearch:itemsPerPage>
<link type="application/atom+xml" href="http://search.twitter.com/search.atom?max_id=21479337184&page=2&q=umbraco" rel="next"/>
<entry>
<id>tag:search.twitter.com,2005:21479337184</id>
<published>2010-08-18T10:22:13Z</published>
<link type="text/html" href="http://twitter.com/undisclosedp/statuses/21479337184" rel="alternate"/>
<title>Have an umbraco site on 4.0.3 are there any security issues that would make me to upgrade? Users are hesitant to let me just for features!</title>
<content type="html">Have an <b>umbraco</b> site on 4.0.3 are there any security issues that would make me to upgrade? Users are hesitant to let me just for features!</content>
<link type="image/png" href="http://a2.twimg.com/profile_images/540081894/nom0001_normal.jpg" rel="image"/>
<twitter:geo>
</twitter:geo>
<twitter:metadata>
<twitter:result_type>recent</twitter:result_type>
</twitter:metadata>
<twitter:source><a href="http://www.realmacsoftware.com/socialite" rel="nofollow">Socialite.app</a></twitter:source>
<twitter:lang>en</twitter:lang>
<author>
<name>undisclosedp (Michael)</name>
<uri>http://twitter.com/undisclosedp</uri>;
</author>
</entry>
</feed>
But then I try to select something but I get no results, why? Examples:
Using an external XML file, why won't it work?
So I'm trying show the results of a Twitter search through XSLT like this:
<xsl:variable name="twitterSearch" select="umbraco.library:GetXmlDocumentByUrl('http://search.twitter.com/search.atom?lang=all&q=umbraco')"/>This results in some beautiful XML:
<feed xmlns:google="http://base.google.com/ns/1.0" xml:lang="en-US" xmlns:openSearch="http://a9.com/-/spec/opensearch/1.1/" xmlns="http://www.w3.org/2005/Atom" xmlns:twitter="http://api.twitter.com/"> <id>tag:search.twitter.com,2005:search/umbraco</id> <link type="text/html" href="http://search.twitter.com/search?q=umbraco" rel="alternate"/> <link type="application/atom+xml" href="http://search.twitter.com/search.atom?lang=all&q=umbraco" rel="self"/> <title>umbraco - Twitter Search</title> <link type="application/opensearchdescription+xml" href="http://search.twitter.com/opensearch.xml" rel="search"/> <link type="application/atom+xml" href="http://search.twitter.com/search.atom?lang=all&q=umbraco&since_id=21479337184" rel="refresh"/> <twitter:warning>since_id removed for pagination.</twitter:warning> <updated>2010-08-18T10:22:13Z</updated> <openSearch:itemsPerPage>15</openSearch:itemsPerPage> <link type="application/atom+xml" href="http://search.twitter.com/search.atom?max_id=21479337184&page=2&q=umbraco" rel="next"/> <entry> <id>tag:search.twitter.com,2005:21479337184</id> <published>2010-08-18T10:22:13Z</published> <link type="text/html" href="http://twitter.com/undisclosedp/statuses/21479337184" rel="alternate"/> <title>Have an umbraco site on 4.0.3 are there any security issues that would make me to upgrade? Users are hesitant to let me just for features!</title> <content type="html">Have an <b>umbraco</b> site on 4.0.3 are there any security issues that would make me to upgrade? Users are hesitant to let me just for features!</content> <updated>2010-08-18T10:22:13Z</updated> <link type="image/png" href="http://a2.twimg.com/profile_images/540081894/nom0001_normal.jpg" rel="image"/> <twitter:geo> </twitter:geo> <twitter:metadata> <twitter:result_type>recent</twitter:result_type> </twitter:metadata> <twitter:source><a href="http://www.realmacsoftware.com/socialite" rel="nofollow">Socialite.app</a></twitter:source> <twitter:lang>en</twitter:lang> <author> <name>undisclosedp (Michael)</name> <uri>http://twitter.com/undisclosedp</uri>; </author> </entry> </feed>But then I try to select something but I get no results, why? Examples:
None of these output anything.. what's going on?
try
I think you are at the root
Thomas
@Thomas Yes, that works fine, that produces the XML that you see..
Sebastiaan, Sebastiaan, Sebastiaan... it's all about the namespaces! ;-)
First try this...
If that doesn't work, then try adding the namespaces to the top of your XSLT.
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:msxml="urn:schemas-microsoft-com:xslt" xmlns:umbraco.library="urn:umbraco.library" xmlns:google="http://base.google.com/ns/1.0" xmlns:openSearch="http://a9.com/-/spec/opensearch/1.1/" xmlns:atom="http://www.w3.org/2005/Atom" xmlns:twitter="http://api.twitter.com/" exclude-result-prefixes="msxml umbraco.library google openSearch atom twitter">Namespaces have caught me out many many times! ;-)
Cheers, Lee.
Hi Sebastiaan,
This is the good old namespace issue... Have a look at this: http://our.umbraco.org/forum/developers/xslt/8016-getXMLDocument-won't-display-any-content
/Chriztian
[EDIT] Arghhh... slain by the might Lee Kelleher :-)
Thanks guys, that helps a lot!
