I was having some issues using umbraco.library.GetXmlDocumentByUrl. I kept receiving this error when saving the XSLT file.
System.Xml.XmlException: An error occurred while parsing EntityName. Line 3, position 106. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String arg) at System.Xml.XmlTextReaderImpl.Throw(String res) at System.Xml.XmlTextReaderImpl.ParseEntityName() at System.Xml.XmlTextReaderImpl.ParseEntityReference() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace) at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc) at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.LoadXml(String xml) at umbraco.library.GetXmlDocumentByUrl(String Url)
I searched the forums here and didn't find a solution. I determined that the issue only occurred with xml feeds outside of our network. Adding a default proxy to the web.config fixed this issue. Here's how to do that:
GetXmlDocumentByUrl and Proxy issue
Locate the <system.net> </system.net> tags
<defaultProxy>
<proxy proxyaddress="http://servername:port" />
</defaultProxy>
I hope that helps someone out.
Also, your specific defaultproxy configuration may be slightly different. For example, you may need to include a password...
Go here for more information: http://msdn.microsoft.com/en-us/library/kd3cf2ex.aspx
