  • Alex 21 posts 41 karma points
    Aug 25, 2010 @ 18:29
    Alex
    Problems getting attributes with getMedia()
    I'm trying to get an attribute of a media node but for some reason it's not returning anything. Strangely the 'id' attribute returns a value.
    <xsl:variable name="media" select="umbraco.library:GetMedia($currentPage/data [@alias = 'mediaId'], 0)" />
    <xsl:value-of select="$media/@id" />   <!-- this works -->
    <xsl:value-of select="$media/@nodetypealias" />   <!-- this does not -->
    If I use <xsl:copy-of select="$media" /> I can see that the 'nodetypealias' attribute is there on the node, but I am unable to select it. Does anyone have any ideas why this could be?
  • Matt Brailsford 4125 posts 22224 karma points MVP 9x c-trib
    Aug 25, 2010 @ 18:40
    Matt Brailsford
    Hi Alex,
    First thing I would try is to use the alias @nodeTypeAlias (that exact casing) as this is case sensitive.
    If that's not the case, can you let us know version of Umbraco you are using?
    Matt
    Aug 25, 2010 @ 18:50
    Alex
    Ha thanks Matt, just worked that out myself too. I was looking at the XML dumped out my <xsl:copy-of /> in Firebug and it had lower-cased all the damn attribute names! Very frustrating waste of time as I was trying to work out what was wrong with my XPath queries!
