  • eddy 43 posts 64 karma points
    Sep 02, 2010 @ 12:18
    eddy
    List subsections and their child articles
    I'm trying to get to grips with XSLT and it's certainly a challenge. I've read lots of forum posts and watched videos but cannot create a relatively simple list.
    Within a main section on my site I would like to list all the subsections and then present their child articles as a nested list. I have managed to present the subsections but the child articles are not being grouped within their subsections. At the moment the child articles are listed in all subsections.
    How can I group them? Here is my code:
    <xsl:template match="/">
      <xsl:for-each select="$currentPage/descendant::Subsection [@isDoc and string(umbracoNaviHide) != '1']">
      <h2><xsl:value-of select="@nodeName"/></h2>
      <xsl:for-each select="$currentPage/descendant::SimpleTextPage">
      <ul>
      <li>
        <href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a>
      </li>
      </ul>
      </xsl:for-each>
    </xsl:for-each>
    </xsl:template>
    I'm guessing I need to add something here:
    but every example I look at seems to offer a different solution.
    thanks, Eddy
    Sep 02, 2010 @ 14:59
    Sep 02, 2010 @ 16:03
    eddy
    I've managed to get the list using various forum topics but particularly Dougs advice above. However in his example all items are listed in li tags as links.
    I would like to style level 3 Items with a h2 tag and the child nodes with an anchor tag. Is it possible to write an if statement for example; if level 3 then <h2>...</h2>, if level 4 then <li><a>...</a></li>?
    Heres my code:
    <xsl:variable name="maxLevelForSitemap" select="4"/>
    <xsl:variable name="source" select="/macro/source"/>
    <div id="sitemap"
     <xsl:call-template name="drawNodes">
        <xsl:with-param name="parent" select="umbraco.library:GetXmlNodeById($source) "/>
     </xsl:call-template>
    </xsl:template>
    <xsl:template name="drawNodes">
      <xsl:param name="parent"/>
        <ul>
          <!-- level is a standard attribute on every node -->
           <xsl:for-each select="$parent/* [@isDoc and string(umbracoNaviHide) != '1' and @level &lt;= $maxLevelForSitemap]">
              <li>
                </a>
                <xsl:if test="count(./* [@isDoc and string(umbracoNaviHide) != '1' and @level &lt;= $maxLevelForSitemap]) &gt; 0">
                    <xsl:with-param name="parent" select="."/>
                </xsl:if
              </li>
            </xsl:for-each>
          </ul>
      </xsl:template>
    Any help really appreciated as I'm slowly losing the will to live.
    thanks.
  • Rik Helsen 670 posts 873 karma points
    Sep 02, 2010 @ 16:43
    Rik Helsen
    just above
    Add something like
    <xsl:choose>
    <xsl:when test="./@level = 3">
    <h2>
    </xsl:when>
    <xsl:when test="./@level = 4">
    <h3>
    </xsl:when>
    <xsl:otherwise>
    </xsl:otherwise>
    </xsl:choose>
    And just after </a>:
    <xsl:choose>
    </h2>
    </xsl:when>
    </h3>
    </xsl:when>
    <xsl:otherwise>
    </xsl:otherwise>
    </xsl:choose>
    You'll probably need to play with the levels (which level corresponds with wich heading)
    Sep 02, 2010 @ 17:03
    eddy
    Thank for the tip Rik however it breaks with the error:
    System.Xml.XmlException: Das 'h2'-Anfangstag in Zeile '38' stimmt nicht mit dem Endtag von 'xsl:when' überein. Zeile 39, Position 3.
     the h2 tag doen't match the  </xsl:when> tag.
    Sep 02, 2010 @ 17:16
    eddy
    I got it working using the code below. Thanks for the assistance!
     <xsl:choose>
                  <h2>
                  </h2>
                </xsl:when
                  </a>
                </xsl:when>
                <xsl:otherwise>
    </xsl:otherwise>
    </xsl:choose>
