  • Shaun ak 2 posts 22 karma points
    Sep 07, 2010 @ 11:37
    Shaun ak
    Styling root navigation using Xslt
    This is my first post, and would like to get some advise on how to style the rootnode with a css class when selected.  I am new to Xslt, so not 100% sure if I am going about this the right way?
    All code using $currentPage when selected work fine it is just the $rootNode code (highlight in bold)
    <xsl:stylesheet
      version="1.0"
    <xsl:variable name="level" select="1"/>
    <xsl:template match="/">
       <xsl:variable name="rootNode" select="$currentPage/ancestor-or-self::* [@level = $level]"/>
    <ul>
       <li>
         <xsl:if test="$rootNode/ancestor-or-self::*/@id = current()/@id">
           <xsl:attribute name="class">current</xsl:attribute>
         </xsl:if>
          <a href="{umbraco.library:NiceUrl($rootNode/@id)}">
            <xsl:value-of select="$rootNode/@nodeName"/>
          </a>
       </li>
    <xsl:for-each select="$currentPage/ancestor-or-self::* [@isDoc and @level=$level]/* [@isDoc and string(umbracoNaviHide) != '1']">
      <li>
          <xsl:if test="$currentPage/ancestor-or-self::*/@id = current()/@id">
            <!-- we're under the item - you can do your own styling here -->
          </xsl:if>
        </a>
      </li>
    </xsl:for-each>
    </ul>
    </xsl:template>
    </xsl:stylesheet>
    Any help/ advise would be much appreciated!
    Sep 07, 2010 @ 11:50
    Shaun ak
    Hi All
    I actually solved my own problem by looking at some of the over posts on this forum!
    The code in bold is what I replaced:
       <li>
         <xsl:if test="$currentPage/@level = 1">
         </xsl:if>
          </a>
       </li>
    All is fine now and really enjoying the Umbraco enviroment!
