After upgrading to 4.5.2 im having some problems upgrading to new xslt schema. The converter by Tommy Poulsen has helped me a lot but im stuck on the following:
Old schema: <xsl:value-of select="umbraco.library:GetMember($mId)/data [@alias = 'memberAvatar']"/>
New schema: <xsl:value-of select="umbraco.library:GetMember($mId)/memberAvatar"/>
Old one works in 4.0.x but new one wont work in 4.5.x.
umbraco.library:GetMember($mId) successfully spits out all member properties but i cant retrieve single properties.
don't know directly the answer to that, but here is a way that will probably lead to the solution. Can you please add the following to your xslt and have a look at the output:
Thnx for the reply. Xml output seemed ok to me, but after fiddeling with the problem for a while longer I found a solution. Posting it here for future reference:
My original code that didnt work: <xsl:value-of select="umbraco.library:GetMember($mId)/memberAvatar"/>
Working code: <xsl:value-of select="umbraco.library:GetMember($mId)/*/memberAvatar"/>
Get member property problem
Old schema:
New schema:
Hi Ernst,
</textarea>That should give you an idea of the xml that gets returned, which should allow you to amend your xpath expression accordingly.
Sascha
Hi Sascha,
Working code:
