  • Eduardo 106 posts 130 karma points
    Sep 15, 2010 @ 21:12
    Eduardo
    Problems retrieving data from a child node.
    Greetings,
    I am trying to retrieve an alias value from three nodes under a parent node but, I am getting confused because I can't find the solution to the problem.
    - The XSLT that I am using to retrieve the data from the nodes.
    <xsl:variable name="identifier" select="/macro/id"/>
    <xsl:template match="/">
      <ul>
        <xsl:attribute name="id">
          <xsl:value-of select="$identifier"/>
        </xsl:attribute>
        <xsl:for-each select="$currentPage//*">
          <xsl:if test="@nodeName != ''">
          <li>
            <img>
            <xsl:attribute name="src">
              <xsl:value-of select="//clientLog"/> <!-- I want to get the clientLogo alias from the child node -->
            </xsl:attribute>
          </img>
        </li>
        </xsl:if>
      </xsl:for-each>
    </ul>
    </xsl:template>
    Can anybody help please?
    Thanks beforehand.
    Regards,
    Eduardo Macho
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 9x admin c-trib
    Sep 15, 2010 @ 21:21
    Hi Eduardo,
    Inside a for-each statement, the so-called "current node" in XSLT is the one currently being processed, so your XPaths in here just need to be relative to that node, so if you need a property you just call it by name:
    <xsl:value-of select="clientLog" />
    - or if you're using v.4.0:
    <xsl:value-of select="data[@alias = 'clientLog']" />'
    /Chriztian
    Sep 15, 2010 @ 21:26
    Eduardo
    Hi Chriztian,
    Thank you very much, your answer helped me.
    Regards,
    Eduardo
