  • GLindqvist 13 posts 13 karma points
    Sep 20, 2010 @ 00:49
    GLindqvist
    Problem with NewsList with the new schema 4.5.2
    Trying to get a newslist to work.
    - Startpage
    - NewsList
    - NewsItem1
    - NewsItem2
    What have I done wrong? It will only output <ul></ul> code via Macro.
    <?xml version="1.0" encoding="UTF-8"?>
    <!DOCTYPE xsl:stylesheet [
        <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
      version="1.0"
        <xsl:output method="xml" omit-xml-declaration="yes"/>
        <xsl:param name="currentPage"/>
        <xsl:variable name="noOfItems" select="8" />
        <xsl:template match="/">
            <ul>
              <xsl:for-each select="$currentPage/ancestor-or-self::*[@isDoc]//NewsItem/node">
                    <xsl:sort select="newsDate" order="descending"/>
                    <xsl:if test="position()&lt;= $noOfItems">
                        <li>
          <span class="newsDate">
                            <xsl:value-of select="umbraco.library:FormatDateTime(newsDate, 'd MMMM ')"/></span>
                                      <href="{umbraco.library:NiceUrl(@id)}"><xsl:value-of select="@nodeName"/></a>
                        </li>
                    </xsl:if>
                </xsl:for-each>
            </ul>
        </xsl:template>
    </xsl:stylesheet>
  • Chriztian Steinmeier 2800 posts 8791 karma points MVP 8x admin c-trib
    Sep 20, 2010 @ 09:02
    Hi GLindqvist,
    You just need to cut the "node" off of the select:
    <xsl:for-each select="$currentPage/ancestor-or-self::*[@isDoc]//NewsItem">
    /Chriztian
    Sep 20, 2010 @ 09:16
    GLindqvist
    Wow, it was so easy. Thanks Chriztian!
