I've just updated Umbraco from version 4.5.0 to 4.5.2 and everything worked fine apart from items which use GetMedia. I've used xsl:copy-of to try and see what is output and it was as follows:
This was the html produced rather that in the OP which was the output from Firebug.
Well simply appending /umbracoFile returned the image. However, I don't fully understand why.Is there a config setting which would mean that I can use "/Image/umbracoFile"? It would really save me from having to change the 4.5.0 which was using that xPath.
I believe when 4.5.0 first came out you had to use GetMedia(.....)/Image/umbracoFile, but in 4.5.1 or 4.5.2 they fixed it so it's just GetMedia(....)/umbracoFile. I don't remember the reasoning or exact issue though
Thanks for getting back to me. I'll accept your answer for lack of better ones :) but I was hoping there would have been a config change I could have used so that my previous code would have worked but I guess not.
Update from 4.5.0 to 4.5.2 problem with GetMedia
<img path="-1,1473,2261" nodetypealias="Image" writername="Administrator" urlname="bookatable" nodename="Book a table" updatedate="2010-09-06T09:45:27" createdate="2010-09-06T09:29:11" sortorder="4" template="0" nodetype="1032" writerid="0" level="2" parentid="1473" version="2db44eee-4524-49e7-b592-70352dd61296" id="2261"><umbracofile>/media/78133/book-a-table.gif</umbracofile><umbracowidth>176</umbracowidth><umbracoheight>97</umbracoheight><umbracobytes>13235</umbracobytes><umbracoextension>gif</umbracoextension><alttext></alttext><img width="" height="" alt="" src="">
So far so good. However as soon as I add /Image or /Image/umbracoFile, nothing gets returned.
Any ideas?
David
Hi David,
-Tom
Hi Tom,
David
