I have a page that represents a list of items (quotes) on the page is the above data type that I set up and added two properties to it 'quote' and 'by'.
As the quotes are shared by all my pages this is why they are in a page seperate from my site (common content folder).
I have the following XSLT for looping through the quotes on my page.
<xsl:value-of select="$quotesPage" />
The above line returns all the quotes but the loop doesn't loop through each node as it should (according to the developer see his xslt). Can anyone help please?
<xsl:variable name="minLevel" select="1"/> <xsl:variable name="quotesPage" select="umbraco.library:GetXmlNodeById('1092')"/> <!-- Input the repeatable custom contents property alias here --> <xsl:variable name="propertyAlias" select="string('quotes')"/> <xsl:template match="/"> <xsl:value-of select="$quotesPage" />
Just to make sure - your not using 4.52 with new schema are you? In that case you'll need to change that xslt. I think this would do it (but I'm not experienced with the new syntax so I might very well be wrong ...)
$quotesPage/quotes/items/item
Whats that "Live Editing support for related links" btw?
Regards,
Jonas
Ps. I'm using repeatable custom content for the same purpose (with legacy schema though).
<!-- Input the repeatable custom contents property alias here --> <xsl:variable name="propertyAlias" select="string('quotes')"/> <xsl:template match="/"> <!-- The fun starts here --> <xsl:if test="$quotesPage/quotes/items/item">
</xsl:if> </xsl:for-each> <!-- Live Editing support for related links. --> <xsl:value-of select="umbraco.library:Item($quotesPage/@id,$propertyAlias,'')" /> </xsl:if>
</xsl:template>
<msxsl:script language="c#" implements-prefix="randomTools"> <msxsl:assembly href="../bin/umbraco.dll"/> <![CDATA[ /// <summary> /// Gets a random integer that falls between the specified limits /// </summary> /// <param name="lowerLimit">An integer that defines the lower-boundary of the range</param> /// <param name="upperLimit">An integer that defines the upper-boundary of the range</param> /// <returns>A random integer within the specified range</returns> public static int GetRandom(int lowerLimit,int upperLimit) { Random r = umbraco.library.GetRandom(); int returnedNumber = 0; lock (r) { returnedNumber = r.Next(lowerLimit, upperLimit); } return returnedNumber; } ]]> </msxsl:script>
Repeatable custom contents package question
Hi!
$quotesPage/quotes/items/itemWhats that "Live Editing support for related links" btw?
Regards,
Jonas
Thanks Jonas, is there any documentation on the new schema? I didn't even know one existed.
Here is what I ended up with to get the code working. What is happening is that I have a list of quotes and show one at random:
