  • Nicolai Sørensen 42 posts 66 karma points
    Oct 01, 2010 @ 10:46
    Nicolai Sørensen
    mediaCurrent problem
    From being pretty new to umbraco I hope you guys can solve this before i tear my hair of ;)
    - I have created a MediaType called Flash and given the same properties as File
    - I have uploaded a Flash File which I have called through and macro using MediaPicker.
    - The variable is using MediaCurrent
    Problem:
    When I call the macro $fileId shows "/demo/media/103/top.swfswf533359" but $fileId/node/data[@alias = 'umbracoFile'] gives nothing.
    What am I missing?
    Oct 01, 2010 @ 10:54
    Kim Andersen
    Hi Nicolai
    Can you provide us with your XSLT-code that you use to render the content?
    I think you are pretty close.
    Try this approach:
    <xsl:value-of select="$fileId/data[@alias='umbracoFile']" />
    From what I can see, you have got the XML content of the media-item in the $fileId-variable, but I'm just guessing from the details you provided above :)
    /Kim A
    Oct 01, 2010 @ 11:07
    Nicolai Sørensen
    <xsl:template match="/">
    <xsl:variable name="fileId" select="/macro/FileId"/>
    <xsl:variable name="fileURL" select="/macro/FileURL"/>
    <xsl:variable name="fwidth" select="/macro/FWidth"/>
    <xsl:variable name="fheight" select="/macro/FHeight"/>
    <xsl:variable name="cssId" select="/macro/CssId"/>
    <xsl:variable name="urlParameters" select="/macro/UrlParameters"/>
    <xsl:if test="$fileId != '' or $fileURL != ''">
      <xsl:variable name="trueFileURL">
        <xsl:choose>
        <xsl:when test="$fileId != ''">
          <xsl:value-of select="$fileId/node/data[@alias = 'umbracoFile']"/>
        </xsl:when>
        <xsl:otherwise>
          <xsl:value-of select="$fileURL"/>
        </xsl:otherwise>
        </xsl:choose>
      </xsl:variable>
    Tried removing "node" but nothing happened
    Oct 01, 2010 @ 11:21
    Kim Andersen
    Are you using the new or the old XML schema?
    And what does your $fileId contain? Only the choosen id from the media picker?
    If $fileId contais a media id you shopuld be able to get the path to the media this way if you are using the old schema:
    <xsl:value-of select="umbraco.library:GetMedia($fileId,0)/data[@alias='umbracoFile']" />
    And this way if you are using the new schema:
    <xsl:value-of select="umbraco.library:GetMedia($fileId,0)/umbracoFile" />
    /Kim A
    Oct 01, 2010 @ 11:31
    Nicolai Sørensen
    I'm not sure what you mean, but this is the macro
    <umbraco:Macro FileId="1081" FileURL="" FWidth="960" FHeight="250" CssId="" UrlParameters="" Alias="InsertFlash" runat="server"></umbraco:Macro>
    In the macro FileId then becomes "demo/media/103/top.swfswf533359", guessing from mediaCurrent processing it.
    I have tried both your examples and on the mainpage it writes "error in the macro file"
  • Matthias 87 posts 173 karma points
    Oct 12, 2010 @ 15:43
    Matthias
    i don't know if you already solved it. I had the same problem.
    If you use the old schema (and i guess you do) you have to insert a "*" to get the correct result:
    <xsl:value-of select="umbraco.library:GetMedia($fileId,0)/*/data[@alias='umbracoFile']" />
    Oct 12, 2010 @ 15:48
    Nicolai Sørensen
    Ty so much Matthias.
    Just tested it and the did the trick.
